Question about Vacuums
How do I fix a squeak in a hardwood floor - Vacuums
  • 2,760 Answers
Squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
Posted on Jan 03, 2017
How to use on hardwood floors
yes but if they are laminate dont use wet cleaner vac
Jan 08, 2018 | Vacuums
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
How to refinish hardwood floors
Sometimes, you just have to find the help that you need. That being said, you might want to go to Superior Hardwoods, as it will be of great help to you.
Feb 03, 2013 | Vacuums
How do I stop squeaking parts of my hardwood floors?
sprinkle the joints with baby powder,that will lubricate the joints
Oct 01, 2012 | Vacuums
How do I stop certain parts of my hardwood floors from squeaking? It's in an up stairs bedroom .
The good news about your squeaky floor is that you have many options for repairing it. Most home improvement stores sell squeaky floor "kits" that may be all you need. Before even heading to the store, try pouring baby powder into the squeaky spot(s). This will absorb the space between the boards and may be all you need to finally get some peace..
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
Can I use the shark steamer on my oak hardwood floors?
Yes, it will work fine on hardwood floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Shark Steam mop and loved it for my kitchen vinyl floor. We just moved into a new home with hardwoods everywhere and I was wonder how well it worked on wood and laminated wood floors.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
It works great on hardwoods and laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Feb 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Can you use irobot Scooba on laminate floors?
they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
Mar 21, 2009 | iRobot 5800 Scooba Vacuum
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Jan 27, 2009 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
