No VGA signal to monitor screen why is that? - Computers & Internet
  • 2,760 Answers
If a laptop is your source these need to have there vga outputs enabled with a "F" key on the top row inorder to work
Posted on Jan 03, 2017
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: my monitor cannot pick up signal.
If your monitor displays No Signal, it means there is no video signal coming from the computer. Monitor is working fine.
It may just be the monitor cable. Do you have another one, or one you can borrow from another computer, for a test?
If a known, good, working, monitor cable yields the same results, the problem is your computer.
The computer isn't working.
The problem may be due to the power supply. Most of the time it is.
This statement is given because of,
A) Most of the computers that come to my shop, have this problem.
B) If you look on the internet, it is a common problem stated.
C) Most of the problems on here, are due to power supply issues with the computer.
You may see, or hear fans spin. Lights light, and it may sound like the harddrive is running.
Problem is, the processor doesn't have enough power to operate, so nothing is going to get done.
The main rating for power of a power supply is Watts.
Voltage times Amperage = Watts.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 55 to 125 Watts.
Depends on what processor it is.
The power supply has 3 main voltage power rails.
A) The 3.3 Volt rail
B) The 5 Volt rail
C) The 12 Volt rail
If the power supply develops a weak, or failed voltage rail, the Processor does not get enough power. Won't turn on.
Most of the time a power supply fails because it is dirty inside. (And the inside of the computer)
The simple solution is to unplug the computer from power, open the computer case, and use a can of compressed air for computers, on a regular basis.
Install the plastic 'straw' into the nozzle, and shoot air into the inside of the computer in rows.
Start at the top inside part of the computer, going from one side, towards the other side.
Then go down towards the bottom.
Tip the case slightly with one hand, and use the other hand to shoot air towards the bottom, to remove the remaining dust/dirt.
Shoot air into the power supply, from the back of the power supply through the ventilation holes. (Inside of computer)
Use a few Q-tips, and clean the fan blades, center hub, and surrounding cage, of the power supply fan, then use air. (Back of computer)
The rest of the time the fault lies in bad Electrolytic Capacitors inside the power supply.
CAUTION!!
NEVER open a computer power supply!
The Electrolytic Capacitors inside, hold a charge for Weeks, sometimes Months, after the power supply has been unhooked from power!
You can get shocked Badly, or even Fatally!
Best solution is to replace the power supply. If you have another working power supply, you could use it for a test.
[Be sure to work on a table. Be SURE to touch the metal frame of the computer case, (Case open),
BEFORE you reach inside!
(Computer UNPLUGGED from power)
Your body carried Static electricity. Static can fry out computer hardware components, in a New York second!
Computer unplugged from power you're safe.
Touch the metal frame before reaching inside, the computer is safe.
If you get up for any reason, leave, then return, touch the metal frame again!]
Posted on Jan 03, 2010
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
Powers on but no screen
There may be problem with your Monitor or VGA Card.
When you turn on computer after sometime the monitor light will be orange colour it mean there is no fault in monitor. VGA Card is not sending signal on the monitor. you should change your VGA Card slot if the problem is still exist. Replace the VGA card or have a local tech take a look at the VGA card.
Mar 16, 2010 | Computers & Internet
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Brand new Monitor blank screen says No Signal
There is nothing wrong with the monitor. The LCD is not recieving any signals from the PC. Either you are connecting the VGA cable incorrectly or your VGA card is not set from the PC BIOS. The VGA cable might also be faulty.
Recheck that all the connections are clean and secure. If you are using a PCI-E or AGP card, the computer BIOS should be set to send the video signals through the PCI-E or AGP card. Follow the procedure in your motherboard manual.
If your pc has on-board graphics then you should connect the VGA cable to the on-board VGA out connector.
Oct 19, 2009 | Acer X203H bd Monitor
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Jul 19, 2009 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
