How do I switch to the DVD player - Televison & Video
Sony remote RM-DX500 not working with Disc Explorer 400 DVP-CX985V, but does work with tv. How can I program it to work the dvd player?
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Oct 11, 2010 | Sony DVP-CX985V Multi-disc DVD Player
Tip
Pioneer DVD-400V DVD Player Interlace Reset
Pioneer DVD-400V Interlace Reset
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  1. Switch everything off.
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V HDMI Reset
on Jun 06, 2010 | Televison & Video
Tip
Pioneer DVD-400V DVD Player HDMI Reset
Model: Pioneer DVD-400V
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
The screen goes black and it does not read the disk
There should be a switch on either side of the DVD player that says "TFT" and something else.
Shut the DVD player down, move the switch, and turn it back on.
Hope this helps.
BTW, the the switch lets you choose between using the output A/V cables and the DVD player screen.
Jul 06, 2009 | Mintek MDP-1770 7 in. Portable DVD Player...
Dvd player has switched region
this time you check the manual of your portable dvd player, i know its there to changing the region.
Jun 21, 2009 | LG DVDR 313 DVD Recorder
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
I hope that helps.
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
I hope that helps.
Dvd won't eject
thanks fore the reply. I switched off the player and when switched back, press the eject button, presto, it worked. I hope this was not a fluke.
C
Apr 09, 2009 | Televison & Video
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
DVD Player keeps switching on and off
Plug in the DVD player into a different power outlet to see if it's faulty power outlet. If the DVD player is still acting up, then it's either a faulty power supply unit or a faulty main board. Either way you'll have to get it fixed.
Jul 27, 2007 | JVC XV-N212 DVD Player
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
