When I plug it in I get--:-- what do I do next to set it and fry
    Top Expert:
  • Computers & ... Master
  • 26,730 Answers
Set the time.
Posted on Jan 03, 2017
Scotched fry pan
we did not "scotched" on the fry pan
ask a question in your next post and do not make a false accusation.
Jan 23, 2017 | Home
How to set up the keyboard and mouse ijust got from fry's elec.
Both the keyboard and most if bought new recently should be plug and play. Meaning that all you need to do is plug them in and a basic set of drivers should be installed automatically to offer functionality.
Apr 23, 2011 | Computers & Internet
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
8n (front mount distributor)seems to be frying coils, one day working just fine, next doesn't spark at all, New condenser, plugs, wires, rotor,points, distributor cap. Replaced coil last time seemed to...
Had the same problem, but was my fault for bypassing the ballist resistor (my bad). Anyway, I fried the coil. Read all the posts and bought new 12 volt coil (it has been converted before I got it 13 years ago). New points, condenser, cap, rotor. Now it is just my timing is a little off, but I have strong sparky but not enough to fry my coil again.
If anything, keep the ballist resistor. it is needed to drop the voltage to the coil so it doesn't fry.
Jan 12, 2010 | Ford 8N Tractor
Despite 220V power cable plugged in correctly, my hp psc 2175 is dead and showing no signs of life
Forgive a somewhat silly question ... on the back of the printer, or on the power brick, into which the a/c power goes, and from which a cable goes to the device itself, there might be a slide switch, which is hard to push in either direction. This switch will convert the power from 120 to 220 and, depending upon the country in which you are trying to use this device, you should have slid this switch in the correct direction, to provide the proper level of power for the device.
Are you certain that you have set this to the correct level of power for the device?
Please make sure that you have done so at each place for which this can be done, then power on the device and see if it works.
-a.
Dec 25, 2009 | HP PSC 2175 All-In-One InkJet Printer
Changing the heater core in a 1994 Dodge Intrepid, is there any tips or short cuts to make this long job any shorter?
Sorry, nope. You have to get in there and tear it out. OR you can by an electric heater from Habor Fri**t and set it in the seat next to you. Plugs into the cig. lighter plug.
Oct 17, 2009 | 1994 Dodge Intrepid
I can't start mower. Was given to me, I have
look to see if there is a fuel on off switch on fuel tank some have a primer bubble on side of carb press a few times till it is full of fuel hold the bar on the handle to release the brake and pull the cord to start.
Oct 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Rear defrost on olds alero
Remove the interior panel next to the rear window on the passenger side. There should be a small black box (3"x3") bolted there. This box sends power to the rear defogger and carries the signals from teh integrated FM antenna. Often, the end of the plug fries and stops the defoggers from working while the radio has no problems.
The plug into the box is usually melted. It may look like it can be soldered and hardwired to work again, but more often than not the box is fried too. You can get them on the cheap from a JY or get them through GM.
Jul 13, 2009 | 1999 Oldsmobile Alero
Hitachi 51F710A won't turn on
sounds like you may have had a power surge it may have fried the motherboard...have a tech take a look at it to be sure but i think it got hit by electricity
Jan 04, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Nov 08, 2007 | Sylvania 6413TG 13" TV
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
