Question about Kodak Office Equipment & Supplies
SOURCE: Series 3 Printer Not Printing Full Image
unplug power cord. Then hold down the transfer key and the left arrow button at same time and plug power cord back in.
Posted on Apr 01, 2008
SOURCE: Only half of picture is printing
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Posted on Aug 29, 2008
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
SOURCE: Kodak printer dock cartridge is stuck inside printer dock
turn off your printer. Press and hold down the left arrow and the transfer button, turn on printer while holding them down, you should hear your printer make some noises, This will be the head lining up. Open the side door to gain access to the cartridge, push on it to see that it i s"locked" in. Lift up on the Green release button on the inside and your cartridge should come free on its own. Be careful not to try and pry it out for this can void your warranty! http://www.wonderhowto.com/how-to/video/how-to-remove-a-stuck-cartridge-on-a-kodak-g600-printer-dock-249276/view/
Posted on May 18, 2009
SOURCE: Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Posted on Dec 25, 2009
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
Please check the bellow links to have a detailed idea regarding your query:-
http://www.brighthub.com/multimedia/photography/articles/64730.aspx
http://www.ehow.com/how_6139932_fix-batteries-won_t-hold-charge.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kodak EasyShare Printer Dock Series 3
Jun 11, 2010 | Kodak EasyShare Printer Dock Series 3
Aug 04, 2009 | Kodak EasyShare Color Photo Printer Dock
Aug 03, 2009 | Kodak EASYSHARE G610 Thermal Printer
Jul 30, 2009 | Kodak Cameras
Jul 11, 2009 | Kodak EasyShare Thermal Photo Printer
Nov 07, 2008 | Kodak Dock Series 3 Laser Photo Printer
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
23 people viewed this question
