Question about Kitchen Appliances - Others
Don't know how to use programmable key pad to use fryer. Help
How to remove and clean burners of soot
You can purchase deep fat fryer cleaning solutions in a powder form or liquid....we sell them and other companies do too. The key is to boil your product, along with water in the fryer, using a L shaped brush to add in the cleaning process. You may need to do this a couple of times, if your fryer is really bad. If you boil it out, drain it and it's still really cruddy, then use a green pad and scrub what you can manually, then fill it back up, use whatever product you desire, boil it out again, using your L brush too. That will help clean out the drain hole where you drain the grease out, as well as the burners too. This is not an easy job, so if you think 15 or 20 minutes will do it, it won't... It's tough to clean restaurant equipment, as it's used normally 24/7 and not taken care of very well normally. Spills are burnt on, nothing is ever wiped up, grease spills over the sides of the fryer, and the crumbs in the bottom are burnt over and over, as some people don't strain their grease, just using it until it becomes unuseable... It's a tough job, but one we do quite often, and you just have to put in some elbow grease, use your cleaners, along w/the boil out method, a green pad or 2 or 3, and when you are satisfied and done.... Be super sure to rinse all the chemicals out of the frypot before you add any oil to it. Leaving ANY soap in the bottom of the frypot will help to break down your oil and spoil it way before it should, and that's expensive to replace over and over. Keep your temperature down to 325 degrees and that will help you save your oil as well. If you want to really extend your oil, buy and use a additive like Miroil. This is a oil additive that is used to extend the life of your oil, on a daily basis, sometimes twice a day, depending on your hours of operation/business. This additive , along with keeping your temp at 325, straining your oil, and rinsing your pot out well before adding oil will extend your oil so well, that you will never dump a whole vat of grease again....You will get a formula that will tell you how much grease to pull each day and you will replace that amount with new oil....If you have 2 fryers or 3, you would pull oil from your appetizer fryer and put it in the fish fryer, dumping that oil, whatever the measure is, like 3 cups or whatever. The idea is that your appetizer fryer has the lighter cooking foods in it and the fresher oil. The fish fryer can handle the older oil a bit better. All fryer foods will look/taste/ much better all week long, without your foods getting darker as the week goes on... Your foods will also absorb less oil, if you keep that temperature down to 325 instead of 350 or higher. That higher temp also helps to burn your oil up quicker, so keep it down....
I've seen this product work, and every customer I ever sold it to, never stopped using it once they started, and the cost is under a dollar a day.... Your savings are huge, as oil is one of your most expensive costs in the food industry. If you need a place to buy the additive or the fryer clean out products or the L brush, we sell all of it and can ship directly to you. Restaurant Equipment Outlet, Cincinnati, OH 888-542-5959.
Happy Frying...
Nov 26, 2011 | Vulcan EF3 Deep Fryer
I locked my keys in my car
Most cars can be opened using a long steel wire. Watch video for details
Sep 01, 2011 | Chevrolet Malibu Cars & Trucks
Lost the key, tried spare that realized only unlocked the doors in the ignition and the theft light started blinking. Is still blinking and now have original key but key wont turn in ignitionr
you can use the sbb key to copy a new one, Before running SBB key programmer, please insert the blank new key into your car keyhole;turn on ignition switch;Insert SBB 16-pin interface into your car OBD2 diagnostic seat. SBB key programmer copies chip according to car model, and it program key not clone key, it only needs to insert SBB. It is easy to do, you can DIY, if you don't know about the knowledge of the car repair, you need call for help of locksmith....
Sep 01, 2011 | 1998 Ford Explorer
Don't know how to obtain or programme into / playback commercially prerecorded music (easylistening)
Your keyboard layout is set to other countries standard, so check your configuration from the control panel and set to american standard format.
try pressing other key in the numeric pad above to display the a sign, eg. Fn+5, try other numbers also.
Jul 20, 2011 | Computers & Internet
My numbers 1234789 in letter pad don`t work.But if i pres 3,4,5 at one time will open Help in Google Chrome
The numbers five and six don't seem to work on my letter pad. All other number keys work fine. I have a Dell Inspiron notebook. Does anyone know how I can fix this? HELP!!!!
Dec 04, 2009 | Computers & Internet
I donĀ“t know how to use the magnetic cord
the cord sticks to the back of it (right on top of the two prongs)make sure its facing the right wat!
Dec 09, 2008 | Ultrex 416-101 Deep Fryer
I want to change the filter
I tried all over the internet looking for filters, even contacted Sears where I bought the fryer.  All anyone wants to do is sell you another fryer - a bit extreme when all you want is a replacement filter.  In the end, I got a bit creative & solved the problem myself for under $1!
Go to your local supermarket & buy a pack of the thin 'Scotchbrite' nylon pan scrubbers.  Strip the fryer lid apart - 5 screws, cut scrubber pad to size & reassemble.  The scrubber pad is slightly thicker than the original foil filter, but the lid will reassemble.
Happy frying.............
Nov 17, 2008 | Euro-Pro F1066 Deep Fryer
Kitchen Appliances - Others Logo
64 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
