Question about Home
How do you attach the clips for a double sink composite granite sink
  • 2,760 Answers
If what your speaking of is a sink that's made from 5 pieces of granite , id not suggest you try to use clips to hold it on the bottom of counter top , id suggest you either use Hot glue (works fast) or epoxy (2 PART) either of these would keep you from stesssin the material and it wont snap on you a bucket with shims can be used temp to set it all on (weight ) till epoxy dries
Posted on Jan 03, 2017
How to use the clip attachments for Frank drop in sink,no instructions or pics for clips
Just weight the sink with water after running a bead of caulk under the lip of the sink. Finish the bead of caulk before it skins over and then drain the sink after 24 hours. I personally wouldn't worry about using the clips, the caulk will hold the sink securely, and if you ever need to remove it, allow for a much easier removal.
Feel free to contact me if you have any questions.
Brandon Wiese
Brandon@StoneRepairman.com
http://www.StoneRepairman.com
Jan 04, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Need instructions for granite sink oc3322-1, cut-out already done for counter top, ready to put in
There should be a clip kit with the sink if not contact moen you should already have this its part of the deal
Dec 14, 2010 | Moen 25425___ Stone Granite Double Bowl...
Will under mounted sink take the weight of garburator?
The sink should be physically mounted with clips if it is not cast iron, otherwise a cradle made of wood is usually the route I go.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
May 15, 2010 | Jacuzzi Kitchen Iron Black Finish...
We cannot get the mounting clips to stay on
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
May 02, 2010 | Franke Work Top Double Bowl Kitchen Sink...
PROPER WAY TO COMPLETE KNOCK OUT HOLES FOR FAUCET
yes you need 1 1/8 in hole saw,for granite.Also need a squirt bottle to keep the bit wet,try to google ,DIY they might have a video on this .
Apr 12, 2010 | Swanstone KSDB-3120 Compact Double Bowl...
How do I repair a granite composite sink?
I recommend one minute epoxy, available at home depot, lowes, and hardware. it will leave a hairline crack but it will hold like iron
Jun 07, 2009 | Home
Drilling a composit sink for a 4 hole faucet
If is real granite you will need diamond tipped coring bits, if it is a composite then quality hole saws and/or drills will work. Slow and cold is the rule here, do not force the tool and you should be fine.
Mar 13, 2009 | Home
Home Logo
88 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
