Question about Beko Washing Machines
I have a brand new beko 9kg machine and it pauses on a quick or longer wash as I have done two. On quick was which is 28mins it paused at 18 mins to go
SOURCE: beko wm6152w turn machine on
try holding the start/pause button in for five seconds, hopefully it will restart
Posted on Aug 29, 2010
  • 330 Answers
SOURCE: Keeps pausing in the middle of wash cycle. Sits
the timer is busted getting stuck at same point their expensive as well
Posted on Jan 05, 2011
  • 4348 Answers
SOURCE: machine getting stuck midcycle in
Be certain that both hot and cold are on and flowing.
Posted on Jan 09, 2011
  • 6277 Answers
SOURCE: BEKO wma 250s washing machine does
This sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
  • 6277 Answers
SOURCE: beko wm 5140 washing machine is starting its cycle
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Aug 10, 2011
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
I want to stop a programmed cycle and start a new one at beko wml 15062 yl
I alsi have that machine. To stop on program and start another, I've pressed the play/pause button for a few seconds, then waited for the key light to come on. Then I switched to the program I wanted and pressed play/pause again
Jan 26, 2014 | Washing Machines
Beko washing machine wme7247w showing E08
Beko Washing machine? What is that a French Model? LOL
Your water inlet valves (hot/cold) are bad and need replacing.
Jan 19, 2014 | Beko WME7247W Washing Machine
Daily quick program on wme7227b pauses on 24mins and 12 mins circuit board been replaced not solved problem
i had exactly the same problem on my beko, but different model, and it was due to a kink in the water pipe at the rear of the machine that supplies water to the machine. release the kink, and it works perfectly
Mar 13, 2013 | Beko WME7247W Washing Machine
What is erro code 6e on a samsung washing machine
Don"t worry too much about the error code, press pause, and then press pause again, the cycle should continue. If the counter does not countdown, ideally,as long as your washing is in the machine for 30-35 mins that should be ample time, then press pause and put your dial on the final cycle from rinse to spin, if this does not work, try picking a longer wash cycle, leave for 30-35 mins, then press pause and fast-track to your final stage of rinse to spin, Good Luck!
Apr 16, 2011 | Washing Machines
Washing Machines Logo
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
