Question about Technics Audio Players & Recorders
Technics SF MC310 Changer.Replaced drive belt.Reads checking disks and carriage moves about 1/2 way down and back.Then nothing.Will not turn off.
Got it.Moved carriage all the way to the end.There was a disk in the reader and it had to put it back to shut off.
SOURCE: will not boot even from recovery media disks
If you have an XP disk, or even one you can borrow, you might want to try to see if you can boot from that. I have one of those machines that I run with regular XP, I wish you well. A still small voice told me to get the extended warranty, and I am so grateful. Since buying mine in Nov 2004, it's gone in for factory warranty at least 12 different times.
Posted on Sep 05, 2008
  • 122 Answers
You might have to reformat the drive sounds like you got a virus in your boot sector on the hard drive.
I hope you backed up everything you needed. when ya get it running again get an external drive and make regular backups of your stuff.Where did it move the files to ? you should have a backup of your system on your harddrive that came with the machine when you bought it ,try to reformat with this sector of the hard drive its called d: backup
Posted on Dec 31, 2008
SOURCE: cd changer problem Technics SLCH 555
i have a technics sl ch 570 cd player the draw opens to load cd and closes but the cd does not spin when loaded
Posted on Feb 13, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 5. Beeps once when turned on,
Try reinserting the printwheel, check for debris in the printwheel area.
Posted on Jul 06, 2009
  • 51 Answers
SOURCE: My disk reader stopped working and failed to
Hithere jody nemcek
Whatto do when your Xbox Has problems with reading disks and you havetried cleaning the disk.
Thisdoes not mean your Disk Drive needs replacing more often than not itjust needs the laser to be readjusted.
Youcan send this off to Microsoft if your still in warranty because itis included in there free fixes so they will do the collecting foryou, fix it and return the Xbox to you, all for free, but it willtake 4-6 weeks.
Ifyou are out of warranty its the same process as above but its $130 incost
nowa new Disk drive would cost around $75 for a compatible one and youmay need some one to fit it at a cost as well.
WhatI recommend is a XBOXREPAIR GUIDE that will show you the simple steps yourself, youwill be up and running again in less than an hour and the cost is farless than option 2 & 3
FeelFree to leave me a comment if you need further assistance.
Posted on Jun 01, 2011
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
What size carriage drive belt do I need for a technics sc-mc4 compact disk changer & where can I get one. .
take the old belt to ace hardware and find an o-ring that is the same size or slightly smaller.
Oct 22, 2015 | Technics Audio Players & Recorders
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
Door will not open,get checking disc message
I solvwed the problem by removing the cover and found 2 discs jammed into the same slot. removed them and put them in the proiper slos, put back cover, gently tightening the screws incase it happens again.
technics 110 cd changer. model sl-mc310.
Dec 20, 2009 | Technics Audio Players & Recorders
Looking for a drive belt for a SL MC300 Technics 110 CD changer
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Won't play cds
I have the same problem. When you turn it, after a while it justs displays "ERROR". I opened the player and I think the player is stuck on the left hand of the interior. When I lift the lever on the front of the player it starts moving, but on returning to the same place it gets stuck again. I checked to see if any items were broken but that does not seem to be the problem. I suspect that it is caused by worn out items. Any suggestions, does Technics still support this player?
Jun 17, 2008 | Technics SL-MC400 110-Disc CD Changer
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
41 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
