Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
My kitchenaid dishwasher model KUDS01IJWHO electronic panel shows flashing lights. I unplugged the machine to try to reset and it worked for two loads then stopped again. Help.
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
  • 188 Answers
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid superba kuds01ijbs0 rinse only light flashes
Hi there.See if you can find the reset button.If you can't find that unplug it and plug it back in to reset.That should fix the problem
Apr 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Cancel Light Flashing on Kitchen Aid Dishwasher
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
157 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
