Question about Hardware & Accessories
Lost end plate for thermastat can i buy a new one
Noma base board heater
4 Suggested Answers
  • 685 Answers
SOURCE: the base plate is broken, where can i buy it?
Try http://www.tripodquickrelease.com/Generic_Tripods.htm for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Posted on Jun 25, 2010
  • 1796 Answers
SOURCE: connecting thermostat to noma baseboard
Hi!!
Click on the following link to obtain a manual for your Noma Baseboard Heater. http://www.qualitycraft.com/files/QBD-500%201000%201500%20Baseboard%20IM.pdf The wiring instructions are in the manual. The wires at the ends are not supposed to touch each other. You can use either side to connect the power supply to the heater.
On the Thermostat, I believe the Heater uses a thermostat that runs on 220v, your regular thermostat runs on 24v, that's why the thermostat burns. To make your thermostat work you would need to get a single throw contactor with a 24v coil, a 220v to 24v reducing transformer, etc. I think you better off getting the thermostat form the Noma guys.
Posted on Oct 14, 2010
SOURCE: I PURCHASED NOMA 1500 WATT BASEBOARD HEATER AND
I am haveing the same problem.........., the first 10 i installed no problems....... now the last one i am ..............did you have any luck
Posted on Nov 10, 2010
Noma indoor digital timer instructions lost
Here is a link that shows instructions for a water heater digital timer. Based off of the model # you stated.
http://waterheatertimer.org/pdf/Noma-052-8853-timer-manual.pdf
Apr 10, 2017 | Computers & Internet
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
MY HOUSE HEATING SYSTEM IS NOT REGUALTING PROPERLY. THE HEAT IS CONSTANTLY ON AND THE THERMASTAT IS NOT CONTROLLING THE TEMPERATUR. MY BASEBOARD HEAT IS CONSTANTLY HOT AND DOES NOT SHUT OFF. WE TRIED...
Check your wiring to the base board heater itself, is there any jumpers that should have been removed? Are the thermostat leads on the correct terminals at the base board heater? This sounds as though it is wired directly to the power and not thru the thermostat. Please check your paper work for wiring, if you are not comfortable with doing this please consult with an electrician.
Dec 14, 2010 | Honeywell Programmable Thermostat Heater
Just moved into a condo (about 14 years old). Has a programmable Noma Thermostat with no manual. We are having trouble figuring it out. Need help !! Thanks. Stan Plolnicky, Medicine Hat, Alberta
Did you find how to use your NOMA digital thermostat? I live in a condo with base heaters. Have three of those. They are less than one year old. When it got cold recently one of them went up to 34 degrees. I couldn't budge the numbers. It's caput. The second one I caught going up on a cold night this week so I solved the problem by shutting down the electrical box. The base heat came back. But without the manual I am working in the dark.
Pierrette in Ottawa Ontario.
Nov 22, 2010 | Kitchen Appliances - Others
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
Nov 12, 2009 | Heating & Cooling
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Overheating
Posible thermastat sticking closed. If thermastat doesn't open heated water is trapped in the engine causing it to run hot and not allowing hot water to travle to the heater core when called for.
Nov 20, 2008 | 2002 Mini Cooper
Hardware & Accessories Logo
118 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
