Question about Home
Can not remove filter bung from Mira shower to clean filter
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
SOURCE: the low flow light stays on on my mira sport max
yes, they are **** showers!!!
Posted on Apr 12, 2010
SOURCE: my mira sport shower is turning on but there is no
they are cheep carp sold by B&Q.
SOURCE: I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Hi Stephen have given you the correct answer, but don't forget to check the manual of Mira Vie Showers, all showers are different form each other, don't forget to check the manual or you can download the e-manual from here
http://www.qssupplies.co.uk/Brand/Mira/1.htm
Scroll to the bottom of the page
Posted on Dec 20, 2012
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
After about a year after installation our mira thermo shower has started to run cold after about half a minute or so. The same thing happenned to a previous cheaper type of shower which is why we replaced...
Your shower valve has an temp equalizer valve in it, you will have to take it apart, clean all the calcium or debris from it. flush out the hot and cold lines with valve dismantled , cover drain to make sure you don't lose any parts. reassemble with Vaseline. good luck.
Mar 14, 2011 | Home
My mira sport shower when switched on runs afew seconds and stops, then when switched off runs afew seconds then goes off. pls can someone advise. thank you
detach the hose from the shower head and clean the filter screen and do the same with the shower head. When you have the shower head detached turn the water on to the shower and see if anything comes out into a towel or bucket.
Feb 15, 2011 | American Standard 1660.501 Sport Hand...
? faulty overheat function on shower
Check the in line filter in the inlet solenoid valve assembly. If there is crud collecting in the filter this will restrict water flow and the over heat protection will trigger to protect the heater elements
May 12, 2010 | Home
Mira thermastatic shower problem,pressure&temprature.
you mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Mar 06, 2009 | Plumbing
Home Logo
82 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
