Question about Refrigerators
My freezer is cold but the fridge is not.
Fan not blowing air from the freezer down to the fridge
    New Friend:
Check the thermostat,it must be faulty or check the fan is blowing and coil is free of dust or any blockage
Posted on Jan 05, 2017
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
lenwest
  • 150 Answers
SOURCE: Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 16, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fridge not getting cold
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
Refer does not work. Freezer and ice maker work good.
Check your evaporator fan in your freezer. They go quite frequently these days. The fridge gets it's cold air from the freezer via the evaporator fan blowing the cold air down into the fridge and cooling it.
Jun 30, 2011 | Admiral Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
I have a magic chef refrigerator that is not cooling. The freezer is working but nothing is staying cold in the frig. Could this be the thermostat?? Don't want to replace frig for a number of reasons. ...
next time send the model number,where is the freezer is it on top or bottom or side by side,anyway all the fridge does is get cold in the freezer and the evaporator fan blows cold air from the freezer into the fridge section and then it returns to the freezer just goes around until it gets cold enough and then the t-stat tells it to shut down so if the freezer is cold you either have a bad fan motor,open the freezer you should hear the fan blowng around in there if not the evap fan motor is bad,also touch the back inside wall of the freezer if there's any frost or ice on the back inside wall you have a defrost problem,bad timer or board,bad defrost thermostat or a bad defrost heater,the ice doesn't melt off of evap coil because one of the parts have failed,the air ducts get blocked with ice and the cold air can't blow into the fridge section,or if you see ice on the ceiling,side and back walls the door was left open and the air ducts blocked with ice,or one more thing if the freezer is on top and you have water dripping into the fridge section the drain in the freezer is blocked and the defrost water can't go down the drain hose,the water is freezing the air ducts up,the drain has to be cleared and all the ice has to be melted out,and yes there is one more thing it could be, some fridges have a damper in them,all it is is a door that opens and closes to let the cold air from the freezer blow into the fridge section so this is why you have to send the model number.but your problem is the cold air in the freezer isn't getting blown into the fridge section because the fan isn't working or the air ducts are blocked with ice.
Dec 31, 2017 | Refrigerators
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
