Question about Refrigerators
Freezer is cold but refrigerator is not - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
Refrigerator Is Not Cooling What To Check And How To Fix Refrigeration System Basics Chapter 1 Troubleshooting Thermistor Problems in Refrigerators Top Freezer Thermistor Testing Replacement
Posted on Jan 07, 2017
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ... > ... > Home Improvement
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Jan 03, 2016 | Whirlpool W8RXNGMBD Universal Silver 17.6...
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Refrigerator is not getting cold freezer is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Apr 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
the damper vent door that lets cold air from the freezer into the refrigerator isn't opening to let cold air flow,check to see if its iced up,or the cold control that operates it is working
Apr 30, 2010 | Fisher and Paykel E522BRXFD Stainless...
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The refridgerator has not been cold enough, the freezer is fine what should i do?
The refrigerator itself get cold air from the freezer. There is a small opening that lets air from the freezer to go to the refrigerator area. make sure the cold air from the freezer is getting there. Sometimes there might be a restriction on this vent therefore the refrigerator is not getting enough cold air from the freezer.
Jun 28, 2009 | Amana AFD2535DES French Door Refrigerator
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
