Question about Speed Washing Machines
E9 icon appears when the washer starts to rotate at high speed
WILL NOT AGITATE
Will it spin? Have you tried the Delicate cycle?
If it is like my washer, it appears that the high speed part of the motor is the issue. If when it comes to the point where it is supposed to start agitating, but all you hear is a buzzing, grab the tub, the outside edges, not the agitator (you're going to have to use a magnet to override the safety) and turn it clock-wise, and it should start to agitate (you might have to do it a couple times if you don't get it fast enough). Close the lid, but make sure it doesn't stop or you'll have to do it again. When it goes to the low speed agitation, open the lid and make it stop. Close the lid and it should start right back up. When the washer spins, listen for when it goes to the high speed spin, you probably won't hear it gain much speed (it should sound much faster if working correctly).
The motor (which in mine has already been replaced once) kit that is available (~$200-$250) will require some minor re-wiring, as they added a capacitor to the electrical system due to a problem with the previous design (yes, I've had that problem, which was a low speed motor issue, where the washer wouldn't spin on low speed and now it appears to be screwed up on high speed motor.) I'm weighing the options of just waiting for black friday and buying a new washer since ~$500 on motors for this washer is just unjustifiable and I won't be buying another GE, that's for damn sure.
Sep 28, 2010 | GE WBSE2090A Top Load Washer
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
Dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Vibrition at high speed
investigated further by myself couldnt wait
May 25, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Speed Washing Machines Experts
Charles T Nevin
Charles T Nevin
 steve
steve
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
