Question about Sony Televison & Video
Sony XBR-55X-800B screen is half white and half black. What is the issue?
  • 395 Answers
SOURCE: My screen Half Black - Half Red
you have a warranty! the set has a problem either with the panel or the main board take it back to the store where you bought it and exchange it or have it repaired by a factory authorized repair place.
Posted on Mar 02, 2008
welcomejee
  • 10594 Answers
SOURCE: i have a sony bravia xbr 32 inch and the picture
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Posted on Oct 06, 2009
welcomejee
  • 10594 Answers
SOURCE: sony 42in xbr flat screen user's manual
Let me know exact model of your TV and do you see any label on subject port that you want to turn ON, how it looks like?
Posted on Jan 18, 2010
SOURCE: The TV has a Black cloud on the right half of the
My parents have the same issue with their Sony KDL-46V4100 TV and were told by the tech that the LCD screen was physically broken and would have to be replaced. The replacement of the screen would cost more than a brand new TV and the TV is not longer under warranty. After the TV is on for awhile the Black cloud goes away but it always comes back when they turn the TV off/on. It stays for 20 - 30 minutes sometimes. The Tech took both top corners of the TV and pushed one back and pulled one forward to show them he could recreate the problem after the black blob cleared up. By twisting the corners he made the blob reapper which he claimed was becuase of the damaged screen. I have no idea how the screen was damaged? I helped them take it out fo the box and set it up. We never dropped it bumped it once? It's never falled off the stand so go figure? It would be nice to find more people with this issue and get a recall going. Something that expensive should last longer than to two years.
Posted on Jul 20, 2010
ssemul
  • 202 Answers
SOURCE: I'm having the same problem, how did you fix or
as your problem its look like panel problem.for confirmation please send me picture.
Posted on Oct 22, 2010
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Half screen has white line and half screen is ok. half screen with white line has picture also shake
Hello, sit down it's bad news, the display (screen) is most likely bad. the good news, it should still be under warranty. contact Sony, and they should take care of this issue, thanks, Terry
Oct 08, 2012 | Sony XBR46HX929 3D LCD TV
Jul 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony 52 inch XBR with bands of ghosted images
Its a TAB bond Problem with the LCD. You can take apart the TV and install a rubber Bumper to put pressure on the TAB. TAB bonds always get worse... I dont know how long it will solve the issue... but u can get a little more life out of it.
Rember when working with the TV the voltages can kill!!
Heres a link to see someone fixing.
I have the same TV...same problem...common problem...unless u ask Sony.
Feb 14, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
SONY TRINITRON XBR
There any number of problems that could have caused the shut down. Depending on how old the set is make your decision on whether it would be wiser to replace it
Jan 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
