Vogelzang VG5770 keeps reading off E1. Went through manual and I can't seem to get it to work
    Master:
  • 946 Answers
  • don-ohio Jan 03, 2017
    Here's the code E1 info:
    18 Trouble Shooting Guide Display is Flashing "E1" Possible Remedies: (Unplug stove ?rst when possible) Clean any dust off of the windings and fan blade. If oiling the blower does not help, the blower may be bad. If operating the heater on the highest heat setting, the room temperature could increase enough and lead to potential overheating situations. If this happens try oper- ating at a lower heat setting. This pellet stove is designed and tested to use wood pellets. Check for signs of fuel other than wood pellets. No other types of fuel have been approved for this pellet stove. If there are signs of other types of fuel being used, stop using them immediately. A power surge, spike, or voltage drop could cause the high limit switch to trip. Check to see if a surge protector is being used on the stove. If not, recommend one to the customer. If the other items check out OK, replace the high limit switch.
    from manual don-ohio (:^)
Q1 1210-017-199
An E1 reading typically means that your PIC does not detect
cookware on its surface. This can occur for one of two
reasons.
1. Have you placed a pot or pan on the unit? The induction
coils contained within the PIC will only work when they are
in direct contact with a piece of cookware. To maintain your
appliance's effectiveness, always ensure that it rests on a flat
surface and that contact is consistent with your cookware.
Refer manual at this sitehttp://www.nuwavepic.com/resource/pdf/NuWave_PIC_Manual_and_Cookbook.pdf
May 29, 2014 | Hearthware NuWave Precision Induction...
Got induction fan for Volgelzang wood furnace and no instuctions
I don't have one and cant seem to locate one online. You will need to go to a dealer or call them again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/william_c9458c4c1f94e482
Mar 23, 2014 | Vogelzang Norseman Warm Air Add-On...
I have a fitness Edge 491 Recumbent bike that the display window reads E1 . the resistance is hard and I am unable to reset. when I press start stop for 2 seconds it all looks like it will reset but then...
The bike is no longer sold and the company went bankrupt in 2014, so neither support nor parts are available from the company. Try the results of this Google search regarding the E1 error code:
fitness quest edge 491 e1 error Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 25, 2017 | Cycling
Not enough heat coming from my Norseman furnace
I suspect the heat exchanger is caked with soot. The type of wood makes a very big difference in keeping them clean. The top cover is removable to access and clean it. No pallet or treated wood to keep it clean. Don't remove any screws you don't have to.
Dec 12, 2013 | Us Stove Company Vogelzang Norseman Add-On...
My power went out after the power came back on my air conditioner reads e1
E1 might be a stuck key on the keypad... they are sometimes flakey .. maybe water getting into the keypad ... at any rate the remote control usually still works .. eventually sometimes the key pad starts to work again (maybe when it dries out)
So, based on solutions from those other sites, I pulled off the front panel, turned it over and removed the 4 screws from the back of the control pad (not the six screws on the outer perimeter). I looked for a stuck button but did not find one. I just pushed all the buttons a few times in case one was stuck (as suggested on other sites) and that did it!
Hope helps.
Jun 11, 2011 | Haier ESA3109 WallWindow Air Conditioner
My oven went thru the self clean cycle then started beeping. E1-F-5 shows on the screen and the door is locked and no matter what I do or push it just keeps beeping. I have unplugged it to make it stop....
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 19, 2011 | Kenmore Ovens
I keep getting the error "E1" & the dryer turns off ...what does that mean?
I've read in other forums that E1 means the thermistor has failed. As far as I understand, it monitors the temperature of the air that is leaving the dryer and entering the dryer vent. If you're not handy, a service call is in order.
Mar 24, 2008 | Kenmore Elite HE4 Electric Dryer
TOC reading... e1 error
Buy a cd cleaner kit, if it doesn't work have some one capable re-align you laser len. When the unit get use for times the len got tired(worn and mis-align). Goodluck.
Mar 06, 2008 | Panasonic CQ-VD7001U Car DVD Player
Self clean will not start
e1 f5 is saying your door latch is not operating will either be the switch or the latch motor or the latch itsself is out of line and not going into the slot to latch the door depress the door switch then do clean keeping your fnger on the door switch at all times observe if the latch comes out or not if it does its out of line if not its the motor or the switch still keeping your finger on the switch hit cancel
Dec 28, 2007 | Kenmore 72012 / 72014 Kitchen Range
Haier E!
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
Aug 08, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Heating & Cooling Logo
518 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
