Question about Toymax Skyworth SLTV-2663A 26 in. LCD TV
How to unlock panel key skyworth 24e22-8M28S without a remote control
I lock my panel key and the remote was broken how can I switch it on without a remote
My sintech tv shows key lock and I lost my remote
Without a remote control; you can't unlock it.
Mar 15, 2015 | Televison & Video
How can I disable skyworth tv manual panel lock?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Dec 11, 2014 | Televison & Video
Lock key
Channel locked. Refer the user manual for details about to unlock channel.
Jul 01, 2013 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
I have a 2008 Chevy Avalanche with remote door unlock. The keyless remote stopped working on the driver door but still works on all other doors and the tailgate. If I use the key only on the driver door...
Does the switch inside for that door work ? Does the power window work for that door ? Check fuse DDM - 15 amp I/P fuse panel . Do you know where the insturment panel fuse box is located ?
Fuse Block - I/P
Left of the I/P behind the side trim panel
# 4
DDM Fuse
15A
Driver Door Module (DDM)
Do you know anything about automotive electronic's , control module's ? Serial data communication networks ?
Circuit/System Description
The driver and passenger door lock and side window switches are integrated control module switch assemblies. The DDS and PDS door lock switches are normally open, 2 position rocker type switches, with detents for lock and unlock. The DDS and PDS are directly connected to the respective door lock actuator through the door lock actuator control circuits. When a door lock or unlock function is activated from the DDS or PDS, a serial data message lock or unlock command is sent to the other door switch and body control module.
Sep 15, 2017 | 2008 Chevrolet Avalanche
Hyundai santa fe key fob 1 works 1 does not have changed battery deal says to buy new ,can i unlock with key without alarm going off
System operation
Pressing remote control lock button locks vehicle and activates system Fig. 1 . Indicators flash once. Pressing remote control unlock button unlocks vehicle and deactivates system Fig. 1 . Indicators flash twice.
Fig. 1
Synchronization
When
System malfunction. Remote control added or replaced.
How
Access alarm system control module located under driver's side lower fascia Fig. 2 . Set memory switch to SET position. Press remote control lock or unlock button. Set memory switch to OFF position. Confirm synchronization has been successful by locking and unlocking vehicle. Repeat procedure for second remote control. Synchronization can also be carried out using diagnostic equipment.
NOTE: A maximum of 2 remote controls can be programmed. NOTE: If remote control fails, system can be deactivated as detailed in the owner's handbook.
Jul 30, 2010 | 2003 Hyundai Santa Fe
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
How to recode remote to vahicle
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Unlock skyworth tv
You can key in "1979", then press "Vol+" Key to unlock it
Nov 24, 2008 | Televison & Video
Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
Aug 31, 2008 | 2001 Honda Civic
Toymax Skyworth SLTV-2663A 26 in. LCD TV Logo
81 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
