Hi. Where can I buy parts for my AIM DVD Player DVX 505. Not finding anything on the Internet.
The Jacks for the Red, White and Yellow jacks are broken and I want to replace them.
sids8065
  • 61 Answers
SOURCE: Black and White on TV
europe uses PAL and not NTSC..change the setting on the TV or DVD player accordingly. Set the TV system to NTSC or the DVD system to PAL
Posted on Feb 29, 2008
  • 223 Answers
SOURCE: dvd has no color on my new plasma t.v.
Check for loose connections or sockets either on the dvd player or the tv. If none exist try another lead. If this still does not work check the settings on both the tv and dvd player to make sure the input/output of the tv and dvd player are using compatible formats.
Posted on Sep 26, 2008
SOURCE: What are the functions of my input jacks?
The Y, Cr, Cb are referred to as "Component Cables". These are for enhanced quality. These connections must be used, at the min, for HDTV. THe Coaxial orange cable is for digital audio (used with a home theater system.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: Input to 3.5mm jacks
this unit should work great for that...it has an A/V in/out switch so you can use it as a monitor...I plug output from a cable tv box into and we use it to watch tv
Posted on Jan 04, 2009
  • 4 Answers
SOURCE: My TV has only the audio jacks (yellow and White)
yellow is video. white is left audio. red is right audio. just match the colors and leave red unplugged.
Posted on Mar 01, 2010
Connect to a Panasonic home theatre/dvd player
You must hook up the DVD player in separate jacks into the TV with red, white, and yellow cables. To play the DVD player you must set the input in the TV menu
Dec 06, 2011 | LG 55 55LK520 LCD TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I get the audio but video does not come on
hi.... is your player works on RCA connector? if so the audio jacks colored red and white should be inserted to your TV RCA port colored red and white too..the video jacks is yellow try re insert it to your TV RCA port colored yellow....weak video responses sometimes cause by delayed contact...hope it can help...don't forget to rate and vote...good day..
Feb 15, 2011 | Cyberhome CH-DVD 300 DVD Player
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do I connect DVD to TV please
on rear of tv you will have video and audio input jacks red and white are audio yellow is video , make sure they are input jacks the jack will be labled and and on back of dvd player will be red white and yellow jacks that are labled output using the cables supplied with the dvd use the red and white insert them on dvd out corresponding colors and the yellow into the video out, now on the tv take the other end of the cables and insert them into the audio and video inputs again with the corresponding colors audio red and white and video yellow ,,,I hope this helped
Nov 10, 2010 | TruTech Televison & Video
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
May 29, 2010 | RCA DRC247N DVD Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook up portable dvd player to tv
If you have component out jacks in the back (yellow, white, red plugs) you should be able to buy plugging them into your TV's Component IN jacks.
May 21, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
