Question about Maytag Atlantis MDE7400AY Electric Dryer
How do i side vent my maytag atlantis electric dryer?
  • 1,000 Answers
Attached is a link to a diagram of your dryer.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170653
You would have to remove the back panel. Remove the existing vent pipe, install a 90 deg elbow of the same size diameter. Then cut a hole in the right or left side of the dryer cabinet that would line up with the new elbow.
Check the side cabnet of your dryer, it appears on the diagram that there may be a 4" knock out for a side exit vent.
Good luck, let me know.
Regards,
Posted on Jul 21, 2009
My Maytag atlantis MDE7600Ayw takes nearly 3 hours to dry clothes. The back silver metal grill is very hot and it still tumbles, no weird sounds. Any suggestions?
sounds like your vent is clogged or there is lint clogged around the blower wheel. Make sure to check outside where it comes out and be sure all the exaust tubing is free of lint clogs.
May 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a ldg382 gas dryer. The dryer runs and heats a little, and the timer will not advance, stays in same position.
disconnect vent tube, run dryer as it shall work now. I would guess restricted vent tube. Good Luck Tim
Jan 16, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
The clothes only get half dry when the cycle finishes, i have to put the clothes through a second cycle to dry them. maytag atlantis dryer - it has a sensor - maybe the sensor has gone bad?
The first thing to do would be to check your vent. If the vent is partially blocked or crimped and is not venting properly, this would cause your problem. people sometimes have their dryer pushed to far up next to the wall causing the vent to partially collapse. also check your outside vent to make sure good air flow is coming out there. may also have a lint build up inside the pipe. check for this as well.
Jun 03, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How do i remove the top from a maytag atlantis electric dryer?
open the door, remove the two screws holding the hinge and on the opposite side, pull the front panel towards you then lift off. you will then see two 5/16 screws holding the lid down.
Feb 07, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Electric Dryer Atlantis MDE7600AY
sounds like you have a restricted vent . check not only the hose but also the house venting. usually clogged at the screen or flapper outside. another ppular place for a buildup is the inlet under the lint screen. without proper airflow lint collects on element. take care of the quickly as it could lead to a fire.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
533 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
