Sub Titles fault
They are all over the screen and even sub titles are non consistent. Some times the wording lingers even after the present subtitle appears then it jumps all over the screen
  • 4102 Answers
SOURCE: getting sub titles to work
hi glad to help you follow these instructions they should be easy to follow but if you have any problems give me a shout back ok good and hope you lady friend can enjoy all of her films now just remember to select the right language and you should have no problems.
Thanks for using the site and glad to help let me know how you get on ok
Step 1:
Set up your Sony DVP-C660 CD/DVD player. Make sure your remote control is functioning and you can see the display on the TV screen. Load a DVD.
Step 2:
Press “Display” on your remote control. This opens the menu.
Step 3:
Use the arrow keys to scroll down to the “Subtitle” option and hit “Enter” to select it.
Step 4:
You’ll be given a list of languages available on the DVD. Choose one and press “Enter.”
Step 5:
To turn subtitles off, select “Off” instead of a language.
Posted on Mar 08, 2008
Agent Dort
  • 216 Answers
SOURCE: Dynex 32 inch LCD television - Cant remove subtitles
Greetings jcsfo,
Here is a link to a page with the manual for your television. I hope this helps.
http://www.dynexproducts.com/pc-590-23-dynex-32-flat-panel-lcd-hdtv.aspx
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 05, 2008
  • 8 Answers
SOURCE: I cannot turn off the sub titles
Turn off the closed captioning on the TV menu.
Posted on Aug 16, 2009
DerStrom
  • 103 Answers
SOURCE: how can i remove unwanted subtitles
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
Posted on May 10, 2010
SOURCE: subtitles will not switch off
Whilst on TV Mode:
Open the menu and go to features then subtitle.
Switch off analogue subtitle.
Scroll to 1st subtitle and then scroll through the languages until "off" comes up.
Repeat for 2nd subtitle.
Hey bloomin presto!!! They gone!!!!!!! :-)
Posted on Sep 15, 2011
Cannot get rid of sub titles on the TV the button that should remove them does not do anything
Subtitles are embedded in the program material. You may be seeing closed captioning (CC) which usually is enabled/disabled as part of initial set up.
Aug 29, 2016 | Televison & Video
How do I get subtitles off
you can use the remote controller to off the sub titles set up or in the menu button of your tv.
Aug 28, 2012 | Televison & Video
Subtitles will not switch off on the dtv even though I have gone into the menu and selected the off position on analogue. However, i have noticed that the option to switch off sub-titles is only for...
Whilst on TV Mode:
Aug 09, 2011 | Hannspree (K206-10U1-005) Television
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
May 10, 2010 | LG DR-4912 DVD Recorder
Subtitles will not remove from t/v even when subtitle button is pushed on remote control
The sub titles are being generated by your Cable box or the Sat box. Sub titles are generated from two different sources: Cable Box,Satellite Box,U-Verse Box etc.
Check the settings in those sources and make suer the sub title is turned OFF in the tv set.
Apr 16, 2010 | Televison & Video
How to remove sub titles from Sagem Digibox in UK
Bottom row of buttons, second from the left (Picture of screen with a line at the bottom). Press that and the subtitles will come and go as you wish.
Jan 15, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Bush 26" hd ready digital LCD tv brought argos today have gone into menu to turn off subtitles but every time i change chanel there they are. I know by pressing to subtitle button i can get rid of them but...
To switch off sub-titles on Bush 26" HD ReadyTV - the following has just worked for me 19.1.10
1) Select Features on Menu options
2) Switch Analog Subtitle to Off
3) Change Subtitle Type to Hearing Impaired
Good Luck - Geoff - Newcastle
Nov 21, 2009 | Bush Televison & Video
Jun 04, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sub titles wont turn off
It may sound simplistic but many times when a remote starts to act flaky, replacing the battery (or batteries) will cure the problem.
They don't last forever.
Another possibility is that the Closed Caption feature has been set in the menu so a check of basic settings might help.
Finally, the contacts in most remotes consist of small carbon buttons and fixed contacts on a printed circuit board.
The board contacts were once flashed with gold plating but - well, we know what has happened to gold lately, so manufacturers have pretty much ceased to use gold and some don't even bother with nickle now but just depend on the tin-lead solder to last beyond the warranty.
This latter material does oxidize over time and becomes a lot less conductive.
If you can crack the case (sometimes there is a concealed screw or two- be careful) it can help to gently run a pencil eraser over the board contacts to restore their shiny surface.
May 17, 2008 | Philips Magnavox 20MT133S 20" TV
Divx subtitle problem
i did too have the same problem & i call back ther service center , he told me only the original movies with the orignal sub titles that can be played
Nov 10, 2007 | Sony DVP-NS575P DVD Player
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
