I don't understand how to do this. How DO I check antennae connection on tv please?
Hoe to set up the tv and antenna
you either need this, Indoor Matching Transformer Gold 75 Ohm to 300 Ohm Balun Antenna Coaxial Cable Twin Lead for Off-Air TV Video Signal Component Connection Adapter / Converter
25711901-wlg4wwjx1hbxmhorbqissfon-1-0.jpg or one of these,
May 25, 2015 | KZ 2013 Sportsmen Classic 200
I don't want to use the antenna on my Sanyo Ds20930
You have to enter its service mode to rectify this problem. Just contact any expereinced tech, as this is a very risky and skilled work. The tech know, what to do.
May 22, 2012 | Sanyo DS20930 20" TV
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Do i need a antienna for regular tv. if i do where does it go in the back of tv. help
Yes of course you do. It goes on the RF coaxial jack (the same one that cable TV would connect tto) labeled antenna. Don't let anyone sell you a special expensive "digital antenna" because digital TV uses the same frequencies that UHF has always used and thereby requires the same antenna, or at least the smaller portion of the older antennae.
Aug 17, 2011 | Vizio L32 32 in. LCD HDTV
MY TV IS NOT SHOWING ANY PICTURE OR SOUND ON ANY OF THE STATIONS IT SHOW WEAK SIGNAL WHAT SHOULD I DO
I don't think there is any problem with your TV. I think problem is from your cable receiver or antenna depending on the cable network that you are using.
To confirm, connect your TV to a DVD player and let's see if there is going to be sound and picture on your TV. If TV works perfectly with the DVD, then it means your antenna or cable receiver/decoder needs to be check. There might be a temporal network problem with your network provider.
Let me know the outcome of connecting the TV to a DVD player so that I can tell you the way forward.
Your sincerely.
Elect_Comp.
May 16, 2011 | JVC HD-61Z456 Television
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
My philips flat screen tv, one year old, teletext just stopped and get the message on the botton left corner 'no text'.
Please check your antenna connection to the tv, normally this happens if there is an open connection between the tv and the antenna. Also try to move the antenna to a different location.Hope this helps and if you have any question please feel free to ask but do allow me some time to get back to you.
Jan 25, 2011 | Philips Televison & Video
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
