Question about Tablets & eReaders
Un freeze touch screen tablet - Tablets & eReaders
My tablet freezes every minute or so. I have Avast Cleaner but it just cleans casches. What can I do?
Unless your tablet is running Windows then the necessity for any type of anti-virus or cleaner is pretty much obsolete. The reason your tablet keeps freezing is because Avast is using a lot of your resources. I recommend un-installing Avast cleaner as it is only causing more issues than it is helping. By default, Android-based tablets RARELY get ANY kind of virus. I work on phones, tablets, laptops, desktops, etc... and to this day, I have seen only one virus on an android tablet. And even the virus couldn't launch enough to infect the system.
Hope this helps.
Mar 31, 2016 | Tablets & eReaders
My rca 7 voyager ll screen won't respond to my touch on one side of tablet what can I do to fix it
amazing-zone® for 7" Tablet PC Touch Screen Digitizer ...®-Tablet.../B00IRT4YCG, Inc.
Rating: 4.2 - ‎93 reviews
For RCA voyager RCT6773W22 7" Tablet PC New Touch Screen Digitizer Glass Panel... will not accept returns of any desktop or notebook computer more ...for my nephews Emerson Tablet, although this one states it's for an RCA tablet, ... Itwon't respond to touch in about a half-inch band all the way across.
RCA Factory Reset & Reboot Unlock - YouTube
? 3:06
Sep 19, 2014 - Uploaded by Rc Jr
Simple video on how to hard reset RCA Android Tablet. Unlock your ... Is the touch screen being un... ... If it doesn't reboot itself, try it again.. Read more Show less. Reply · 1 .... will this repeat all of my games ,pics and other stuff? ... I have one that won'ttype in certain letters on certain spots of the screen.
Jan 11, 2016 | Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Note 8 still freezes on startup screen after factory reset
you should call to company where you have bought or even better to go in with it
Mar 23, 2014 | Samsung Galaxy Note GT-N5110 16 GB Tablet...
What to do if your xo tablet freezes up
try restoring it to factory settings first
Jan 05, 2014 | Tablets & eReaders
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
Tablet boots screen but wont go into the android
What model of tablet do you have? The when the initial screen is all you see more than likely your tablet/phone is bricked. If this is the case don't worry it can be fixed easily. solution vary from tablet to tablet, to find the proper solution go to, go to the forum, find the maker, model of your device then search how to un-brick your device in that section of the forum. Hopefully you will have no problem, I have had SEVRAL tablets and phones all of which I have bricked If I knew the make and model I could possibly help more.
Nov 13, 2013 | OEM Systems Android World Pad II (PZ180)
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
Android tablet screen freezes
I have an apple android tablet and it freezes at the android with black backround
Jan 26, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
