Question about Refrigerators
What is the location of the defrost control board in 596.73503200
Where is the defrost mechanism located in a kenmore 2218877REL refrigerator
Your model # is not coming up for me, but defrost systems consist of 3 components. Defrost Board or timer depending on model, defrost heater, and defrost thermostat. Heater and thermostat are located around evaporator and Board can be located around controls or on back if unit behind a removable panel. Some can be located around compressor
Oct 08, 2017 | Kenmore Refrigerators
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
Model gss25jetabb. Where can I find the defrost timer?
The defrost timer is built into the control board and is likely not the problem with a defrost problem. Item location 801 in this photo is the control board=> HERE The most likely problem on your model is the=> Defrost Thermostat WR50X10068 and the=> WR51X10059 Defrost Heater location 240 and 230 in the photo=> HERE Appliance 911
Jan 03, 2016 | GE Refrigerators
Where are the refrigerator fuses located for a Maytag msd2652keb
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are no fuses in refrigerators. Individual component failure acts a fuse.
You are locked into defrost.
PART NUMBER: 67004704 - Cost: $116.00
This is located in the upper right inside your control box.
This replacement adaptive defrost control board (part number 67004704) fits several models of side-by-side refrigerators. The adaptive defrost control board starts and stops defrost cycles as the temperature of the evaporator rises and falls instead of on a set schedule.
Shut off the circuit breaker for the refrigerator before beginning this repair. Also make sure you're well grounded (Rub hands on bare metal), because electronic components can be damaged by discharges of static electricity. The board installs behind the digital display in the control panel. Procedures for removing the existing adaptive defrost control board and installing the new one vary among models.
Dec 07, 2014 | Maytag Refrigerators
Where is a Kenmore refridgerator adaptive defrost control board located
You might check in back where the compressor compartment is located. I found one for a side by side refrigerator there when we were looking for that board. It will be a circuit board and they can get pricey.
Sep 22, 2014 | Kenmore Refrigerators
Afb910 freezer not freezing
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board. If that is not the problem then the coil might have a hole in it and needs repair and coolent rechrge.
Aug 26, 2014 | Freezers
Ge refrigerator top freezer is frosting over
Refrigerators that self defrost have three main components that cause defrost to take place. On your model GTH18ECC2RBB there is a WR55X10397 Defrost Control Board
This part is most likely the problem and is found inside the fresh food compartment and inside the control panel. The location is 257 in this photo HERE Sometimes the defrost control board will show burn marks but not always. The other two parts that may be defective are the WR51X10038 Defrost Heater
The WR51X10038 Defrost Heater is location 618 in photo HERE
and the=> WR50X10071 Defrost Thermostat
The defrost thermostat is location 630 in photo HERE a tutorial of how to test the defrost heater and defrost thermostat can be found on the parts pages listed above. I will try to put the defrost heater test below. I think the defrost control board is most likely the problem here so look it over first. Manually defrost the evaporator with a hair drier so you can remove the defrost heater and test for continuity. I am here should you have questions Thanks Sea Breeze
Apr 03, 2013 | GE Refrigerators
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Defrost controls
the defrost heater and termination thermostat are located on the freezer side at the evaporator coils behind the back panel. the control board is located at the rear of the refrigerator behind a metal panel.
May 28, 2010 | GE HSM25GFTSA Side by Side Refrigerator
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
