Question about Home
Mr christmans carousel not turning
I have a Mr. Christmas world's fair carousel of swings which move in and out as the carousel turns. The carousel has stopped turning. I have taken apart the top where motor and clockwork reside but can see no place where the motor can drive the rotation of the carousel.
3 Suggested Answers
SOURCE: mr christmas double decker carousel rotation stopped.
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Posted on Jan 01, 2009
  • 32 Answers
SOURCE: I have a mr. christmas carousel that needs a drive
You may have to do some searching if you can't get it from the maker try hobby shops for cars and trains they may have what you need
Posted on Oct 21, 2010
How can I fix a mr. Christmas animated symphony of bells
Hello, Barbara -
Apparently there is more than one Mr. Christmas "Symphony of Bells" item.
I suggest you contact the Mr. Christmas company directly to find out about an authorized Mr. Christmas repair center. This is the link to the Contact Us page for the company:
http://www.mrchristmas.com/ContactUs.aspx
This is the link to the 2 pages of "Symphony of Bells" products the company has sold:
http://www.mrchristmas.com/Search.aspx?k=symphony%20of%20bells
Best wishes.
Mar 04, 2018 | Audio Players & Recorders
Tip
How to fix a Mr.Christmas Carousel swing and dis assembly
Mr.Christmas does not offer ANY tech support or dis-assembly diagrams. Once you purchase it, that's it. But......you can try this: The carousel consists of an outer roof which snaps around an inner roof (where the horse poles insert; there are four tabs that keep it attached to the outer roof). Outer roof removal; You need to carefully remove the "crown" (which is glued on) You may be able to use a blow drier on the hot setting to soften the glue,but not too hot to overheat any parts. Twist and pull gently and carefully remove the crown. Once the crown is removed, you'll should see a screw. Remove the screw to remove the outer roof.
Make notes of screws and parts from where they came from and where the components are located. Once the roof is removed, you should see the light circuit and connection pad. You will need to unsolder two wires from the wipers,taking care not to loose the springs.You can now unscrew the nut which holds the light contact bracket in place. Take care in removing this piece., then unscrew the contact board while pulling it over the central shaft. You should now be able to remove the inner roof, and you can lift up the main assembly.
You now are at the base and several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. This carousel is driven by a bunch of rubber bands,and If there is no rubber band connecting the shaft to the drive motor,than you have found the problem. If you find that the motor does not function or work, you can check the wiring that runs from the switch to the motor for a bad connection or break in the connection. To reassemble, just reverse the previous instructions. You may have to rotate the roof to allow it to fall into place, it should only go on one way.
on Feb 19, 2010 | Toys
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
Nov 30, 2016 | Washing Machines
Gears won't engage without a " push "
These things are junk. When they go wrong you throw them away.
Dec 22, 2013 | Gold Label Mr. Christmas Worlds Fair...
What size bulb do i need for Mr.Christmas Holiday lighthouse?
I can not say for sure but normally these types of houses take the same bulb you would use in a night light. like a GE 120V 4W
Nov 25, 2013 | Gemmy Mr. Christmas Light Show and Sounds...
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
We can't get the wowwee mr personality to move-he responds with comments. His comments seem like he moving and then is about to run into somehting. He never moves though. We have changed batteries, even...
When you turn Mr. Personality on, he will begin a start-up sequence, after which he will wait for commands from the remote controller. If he does not receive a signal from the remote controller for some time he will go into Default mode. -------------- Sensors overview:------- Mr. Personality is equipped with numerous types of sensors. He has a sonic sensor to detect noises, infrared sensors to avoid obstacles, and a tilt sensor so he can tell you when he's fallen over.-------- Sonic sensor:-------- Mr. Personality has a built-in microphone to detect sharp sounds for his noise detection feature.You can toggle his noise detection using the Preferences menu in menu mode.--------- Note:---If Mr. Personality's LCD screen freezes, or if he appears to be behaving abnormally trying resetting him by turning him OFF and then ON again using the power button located on the back of his wheel base.------------- NOTE: Make sure that you point the remote controller towards the robot's IR receiver so that he receives the signal properly. ----------- Check that the SD memory card and/or USB slot door on the back of his head is closed properly. A smooth flat surface or low shag carpet is the best terrain for Mr. Personality. ---------------- Click this link directly to get the user manual of Mr. personality:--- http://www.wowwee.com/static/support/mr-personality/manuals/Mr._Personality_Manual.pdf ----------------- try resetting the unit as per manual once again.---------------this will help.Thanks.Again.
Dec 27, 2010 | Toys
I have a mr. christmas carousel that needs a drive wheel and a motor for one of the horses. Any idea as to where I can get these or similar
Oct 21, 2010 | Toys
Mr christmas double decker carousel rotation stopped.
Dec 27, 2008 | Toys
Home Logo
87 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
