Question about Canon Office Equipment & Supplies
Canon ir copied as font breakage in 400 - Canon Office Equipment & Supplies
Cogz
  • 1326 Answers
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
Posted on Apr 14, 2008
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
Powder spray in first copy only
clean gently the charging roller with cloth or better to replace the charging roller
Sep 18, 2012 | Canon imageRUNNER 400S Copier
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
My IR 400 canon xerox machine's copy is white
clean the toner unit and clean the scanner ,replace the drum and charger roller (p.c.r) and solve the problem.
and my name is gm prathap kumar guntakal,09573910647
Jan 06, 2011 | Canon iR330-400 PS Ver 1.0
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
I am own a canon IR 400 copier printer. it is persist of black copy for xerox. but printing is alright please solve my problem
Hello sir; When you make a copy, lift up the cover check the exposue lamp is on, if not replace it.
Aug 02, 2009 | Canon imageRUNNER 400S Copier
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
21 people viewed this question
old marine
old marine
