Question about Home
I got my Farberware 7 in 1 pressure cooker a few months ago. Now it starts beeping and has an 08 on the display and won't even turn off without unplugging. What is wrong?
jason0110
  • 66 Answers
SOURCE: hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Posted on Sep 14, 2007
SOURCE: Problem with canon powershot SD1000
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty , or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these Canon repair instructions useful and have managed to solve the E18 problem, write us about how you did it. We're looking forward to your emails. Also, please use the links bellow to bookmark us on Del.icio.us and Furl.
Bookmark This Page on: Del.Icio.Us / Furl
Posted on Feb 29, 2008
pauman
  • 248 Answers
SOURCE: My tefal avanti stopped working
The fuse was burned just change it and it would work good.
Posted on Aug 11, 2008
oddharmonic
SOURCE: Lost my manual for Farberware FPC400 Programmable Pressure Cooker
Found a PDF version of the manual on Amazon.com: Farberware FPC400 manual.
Posted on Aug 24, 2009
Geekman
  • 32281 Answers
SOURCE: dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Posted on Oct 24, 2012
What does the E8 error code on a Farberware pressure cooker mean?
The error code E8 means the pressure protection is not working; here is the link for the manual
https://www.hippressurecooking.com/farberware-7-in-1-programmable-1st-gen-pressure-cooker-manual/
The manual does not discuss possible reasons for this. I have to assume there is some kind of issue with the pressure release valve. take a look and see if it is stuck or there is some kind of buildup in or around it preventing it from operating. There is a manufacturers help line listed and the only thing they recommend is to call it. Hope this helps.
Oct 27, 2017 | Crock Pots & Slow Cookers
I need a manual for a farberware Aluminum Pressure cooker #46689
Try Googling (farberware)(46689)(manual) without parens.
Jul 27, 2017 | Crock Pots & Slow Cookers
Using Farberware 7-1 pressure cooker food is taking long time to cook. Lid is sealed and cooks under pressure. How to set for high pressure cooking and other pressure setttings?
This question was posted in the wrong category but it would be advisable to Google (Farberware)(7-1)(manual) without parens to get instructions for use.
Jan 15, 2017 | Crock Pots & Slow Cookers
Technique model 89759. Where can I get a user's manual?
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Dec 14, 2015 - Free downloadable copies of pressure cooker instruction manuals for stove top ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet .... SunbeamPressure Cooker Manual; Technique Pressure Cooker (see Deni); T-fal ... Tower (see Fagor for similar models); Tramontina Pressure Cooker Manuals ...
Technique Oval Talking Electric Pressure Cooker Manual ...
www.hippressurecooking.com/technique-oval-talking-electric-pressure-c...
Oct 7, 2009 - Technique Oval Talking Electric Pressure Cooker Manual. 44 ... ForTechnique Pressure Cooker model numbers: 99800, 99801, 99802, 99803, ...
Technique by Cook's Essentials Digital Pressure Cooker ...
www.hippressurecooking.com/technique-by-cooks-essentials-digital-pres...
Oct 18, 2009 - For Cook's Essentials Model Number: DYB350 Please wait a moment for ... Technique by Cook's Essentials Digital Pressure Cooker Manual.
Jan 19, 2016 | Home
Looking for manual for the Farberware 7 in one programmable pressure cooker
Free downloadable copies of pressure cooker instruction manuals for stove top pressure cookers, ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet.
FARBERWARE FCP412 USE & CARE INSTRUCTIONS ...
www.manualslib.com > Brands > Farberware Manuals > Coffee Maker
View and Download Farberware FCP412 use & care instructions manual online. ...Salton use & care instruction programmable coffeemaker fcm12ss (12 pages) ... TOLL FREE: 1-888-881-8101, Monday - Friday, 7:30 a.m. - 6 p.m. CST Please ...
Farberware 6-Qt Digital Pressure Cooker - Walmart.com
Jan 01, 2016 | Crock Pots & Slow Cookers
Manual for farberware nutrimaster pressure cooker
Here are three downloadable Faberware pressure cooker manuals, yours is bound to be one of these!
http://www.hippressurecooking.com/category/manuals/faberware/
Apr 07, 2014 | Farberware Kitchen Appliances - Others
Where can i find a manual for the farberware 8 qt pressure cooker?
manuals for this item can be purchased from video display corp in cleveland ohio for $7
i would be willing to buy your cooker as mine has a missing lid -- i can be reached at
autumnlf@comcast.net
Oct 31, 2009 | Faberware FPC800V 8-Quart
Today I purchased a display model of the Farberware FRA10ST 10-Cup Rice Cooker at Linens & Things. It has all accessories, but came without box, instructions, or recipe book. Is it possible to receive a...
We purchased the same rice cooker from Linens and Things and it also was a display model. They let us test it before we purchased it because there were NO RETURNS OR REFUNDS, but we were only able to see that it turned on. After one time cooking with it, it stopped working and now we have lost our receipt to ship it in for a warranty claim so we are out of luck....We too, find it hard to locate any manuals, last time we buy out of box just to save $5.00!!!!
Nov 29, 2008 | Farberware FRA10ST 10-Cup Rice Cooker
Home Logo
100 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
