Question about GE Blenders
Blendetr parts i need a pitcher base for a ge blender model # 169169
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
I'm trying to attach assembly to glass pitcher and I can't screw the hex nut to the bearing holder -- so few threads showing through underside of pitcher after all the washers are put on.
If all the parts you have are specific to that particular blender (not a "universal" replacement part) you may have the wrong replacement part. Otherwise, you may not need to use all the parts provided in the package as they might supply several parts used in different models. Contact the part supplier and verify the model of your blender against those they supplied.
Jul 14, 2015 | Waring 007314W Blending Assembly
Where do I find a replacement pitcher?
Link, Can you tell me what brand your blender is? This is usually found under the blender base or right on the front where the buttons are. Then we can tell you whether there are replacement parts or not.
May 08, 2015 | Blenders
I need a replacement Pitcher
Just go to your search engine (I use Google Canary) and type in "replacement pitcher and manufacturer, model name and/or model number". If you look on the base of the unit it should have the model name and number for you, usually on the bottom.
Mar 26, 2015 | Blenders
I NEED A PITCHER FOR BLENDER MODEL KSB540WHO
The jar assembly for the KSB540 is part W10503762. this is for the 48oz jar assembly. Here is a link to the product KitchenAid Blender Jar Assembly for KSB465
You can also use the 56oz jar on your blender, which is part number W10555711, here is a link to that product as well: KitchenAid Blade Jar Assembly W10555711
Nov 26, 2013 | KitchenAid KSB5 Professional Stainless...
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
172 people viewed this question
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Blender Expert? Answer questions, earn points and help others
