Question about Panasonic KX-T7630 Corded Phone
CO Buttons i like to program the above thanksoded
Press Program, co button you want to work with, 2, enter the desired number you want it to dial, press the auto dial/store button, then press the exit button
Posted on Mar 19, 2008
How do I program the Flexible Outside (CO) Line Buttons? The manual doesn't say!
if you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Jun 09, 2015 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 '
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I set the One-Touch Dialling to CO. Please teach me how to cancel this setting.
    The only buttons you can set to CO are the left side buttons with lights, so assuming that, press PROGRAM the button dial 2 STORE. That clears the button. Now, just in case you lost the sequence of buttons for outside lines, from the bottom press the left side buttons and read them. If they're not in 1234 sequence, dial 0x STORE to restore the CO line that belongs there.
    Jul 01, 2011 | Panasonic KX-T7730 Corded Phone
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    How do I program the speed dial buttons? thanks
    A 7730 phone has 24 buttons. The left side buttons are CO buttons with lights, the right side are Personal Feature buttons. To program the buttons on the right side, you press PROGRAM, the button, and dial 9-and the number then STORE. The left side buttons require a "2" first.
    Oct 22, 2009 | Panasonic KX-T7730 Corded Phone
    How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
    Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
    Which ones are you looking for?
    Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
    System speed dial numbers are entered from the main or manager's phone under system program 001.
    Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
    KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
    Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
    To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
    The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
    Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
    Setting a CO button to flash for a specified number
    I assume that the program sequence that you started with was:
    [Program], 99, [CO-09 Button], 2, [desired phone number], [Store].
    To change it back to CO-09:
    First go back to the phone that needs to be corrected,
    [Program], 99, [CO-09 Button], 0, 09, [Store].
    Jun 23, 2008 | Panasonic KX-T7453 Corded Phone
    Need to program pf buttons on kx-t7730
    Press Program Button
    Press Button to be Programmed
    Dial 1 - Plus extention number to be stored on button
    Press button directly under 'ENTER'
    Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7630 Corded Phone Logo
    154 people viewed this question
    Top Panasonic Lands Phones Experts
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
