Question about Kitchen Appliances - Others
Have a LG fridge icemaker AEQ73110208 ordered a replacement they sent me AEQ73110210 need to know how to connect as the connectors are different
Model no LFX25974ST/04
MrScary66613
  • 1990 Answers
SOURCE: Coolant fan electrical connector, wires pulled out
I usually don't tell this But, I am REALLY Busy right now. Call the Dealership Closest to you and ask for Service, Tell them you are a Mechanic and your Problem. They more than likely will tell you over the Phone. That is the Fastest way to accomplish this!
Posted on Jan 02, 2009
SOURCE: How do I know which icemaker replacement to order
Use p/n 4317943
Posted on May 16, 2010
shastalaker7
  • 1515 Answers
SOURCE: Squirel ate through wire harness
Double check the firing order on plug wires, with no power. Also, the wires have to be in the right order on the coil pack. I don't have the manual at hand for this auto, but you can place a few calls and find out the correct order on the coil pack. Shoot the squirrel the first chance you get, just kidding, but check the complete engine firing system to make sure you did not miss anything they may have chewed through you haven't seen yet. Good Luck to you.
Shastalaker7
Posted on Feb 23, 2011
richroth
  • 9472 Answers
SOURCE: On a Maytag fridge-model#MF12266AES--whats the
You need to remove the 2 or 3 screws that secure the ice maker to the wall and drop the ice maker to get access to harness plug and remove the ice maker.
Posted on Sep 13, 2011
imufo2
  • 3773 Answers
SOURCE: lg lfc25770st/04 icemaker problems. The icemaker
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 27, 2011
Need ice maker parts breakdown AEQ36756907
Hi.
The icemaker AEQ36756907 is sold as a single part. For this reason the manufacturer (LG) does not provide a diagram with the exploded view of the ice-maker assembly (here part). A diagram with the icemaker position in the whole fridge assembly is available in the service manual. Here an example with the same icemaker shown at page 49 in position 600A.
Regards.
Ginko
Other models are similar.
Dec 15, 2011 | LG LFC25770ST (250 cu ft) Bottom Freezer...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
My one year old (but new condition) LG fridge was left nicely wrapped up inside the box unused for over 6 months as I was travelling. After I returned home, I unpacked it, cleaned it up and put it on to...
first question, Did you contact lg and they sent a repair man, or did you just pick one. If you picked the person, them your stuck with whatever happens next. I from experience where I work, If you went through lg, and problem was not resolved, and could verify that the purchase was made within a year. You would most likely end up with a new fridge from our store, with no cost to you.
Mar 24, 2011 | Heating & Cooling
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Icemaker overflows water into the ice bin
The ice maker should be replaced.
You can order it on line and replace it yourself.
1 screw and a wire harness connector.
LG part# 5989JA1005F about $104.00
Factory service is availiable in Dallas.
Call LG back if you need a technician if they are not helpful please let me know.
I work for the factory!
Jan 16, 2010 | LG LSC26905TT Side by Side Refrigerator
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Have a 2005 model#LRSC26925TT LG fridge with front ice&water disp. and digital panel. Ordered replacement funnel and frame since mine is outdated and need to replace. Can we replace on our own and...
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Jul 21, 2008 | LG Refrigerators
LG 800
They are the same, side buttons are in different order, and you can connect it to the computer for movies games pics and music. its better!
Aug 19, 2007 | LG KG800 Cellular Phone
Kitchen Appliances - Others Logo
75 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
