Question about Samsung Refrigerators
SAMSUNG RF28HMEDBSR ICE MAKER DRAWER IS JAMMED AND WON'T OPEN?
SOURCE: Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Posted on Aug 30, 2007
  • 1073 Answers
SOURCE: ice maker is not functioning
replace the cold control
Posted on Apr 19, 2008
  • 489 Answers
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Posted on Jun 08, 2008
  • 71 Answers
SOURCE: water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
Posted on Sep 30, 2010
My SAMSUNG RF28HMEDBSR/A, isn't making ice. It doesn't seem to have a reset button or a way to bring out the ice maker. We have ice/water in door on left side. Please help.
Ice makers require a certain temperature to be maintained in order to work. Be sure your freezer temp is close to 0F. If temp is ok, is Ice Maker getting water? If not, there may be a problem with water valve. Or may be faulty ice maker.
Sep 23, 2017 | Samsung Refrigerators
Water flow very low and ice maker doesntwork
Try replacing water filter. when you get the new filter fill it up at the sink first. after you install it run about a gallon of water through it
Jul 17, 2016 | Samsung RF28HMEDBSR Refrigerator Counter...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
How do I replace a broken ice full guide?
The ice maker is easy to remove once you get the drawer off the slides. There are two plastic clips located near the back of the drawer that attach it to the slides. Pop those out and lift the drawer out. Pull off the plastic ice maker cover to expose the mounting screws. Remove the two screws holding the assembly to the top of the freezer, then slide the ice maker forward about 1/2 inch. It will drop down a few inches, allowing you to unplug the wiring connector and remove it as a unit. The ice full guide is then easily removed.
Sep 06, 2013 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Icemaker 3 drawer fridge
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Samsung Ice Maker--Ice block and now no water flow...
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Aug 23, 2017 | Samsung RF265AA Bottom Freezer French Door...
Ice maker spills ice
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
Jun 29, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
