MY DRAFE INDUCER MOTOR MAKES LOUD ELECTRICIAL NOISE BUY N MOTOR WONT ENGAGE IS IS FREE WHEELING THEN FURNACE TURNS OFF BUZZING QIUTS THEN 7 MIN LATER FURNACE TURNS BACK ON AND INDUCER MOTOR FIRES UP.
ITS A RHEEM QUIET 80
    Top Expert:
  • Heating & Co... Master
  • 34,089 Answers
The draft inducer has failed and needs to be replaced.
Posted on Jan 03, 2017
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
1999 goodman furnace draft inducer working 50% of the time
All the symptoms point to a stack blower that needs replacement
Feb 09, 2013 | Heating & Cooling
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Buzzing
If it is a buzzing noise, it is the Ballast for the lamp.
If it is more of a grinding sound, it is the Color Wheel motor.
Does it go away when you turn off the tv? If so, does it stop abruptly or does the sound tend to get softer (winding down noise)
If the noise stops abruptly it is probably the Ballast.
If the noise takes several seconds and seems to get softer until it stops about 30 sec later then it is the color wheel motor.
Richard Bartlett
Apr 02, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My Goodman GMS 90703BXA gas furnace started making higher then normal pitch sounds yesterday. The noise seems to come from the forced draft fan and it only happens in say 3 out of 10 starts so far. The fan...
Check the vacume in your inducer motor. Ensure it is pulling at least -9. If you don't have the equipment, you'll have to wait till it has a problem. Or, pay a tech to come out and service your system, with particular attention to the inducer fan..
Dec 07, 2008 | Heating & Cooling
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Wont spin
WHEN YOU SAY IT MAKES A BUZZING SOUND DOES THE DRUM TRY TO TURN.MOHAMED
Sep 16, 2008 | Washing Machines
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
