Question about Troy-Bilt Garden
Troy-Bilt Pony 13AN77KG211 Need step-by-step how to change upper drive belt.
  • 3 Answers
SOURCE: changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Posted on May 13, 2009
  • 173 Answers
SOURCE: my troy built pony drive belt broke. what do i
Take to auto parts store.
Posted on Jul 08, 2009
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    • 12 Answers
    SOURCE: Had to change the small drive belt that drives the
    You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
    Posted on May 03, 2010
    • 3911 Answers
    SOURCE: I have a troy bilt pony and the drive belt to
    well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
    Posted on Apr 06, 2011
    I need the actual measurements of the troy bilt pony 42" drive deck belt
    Mtd doesn't sell the belts by size, you look up the Model number and you will find a part number for the belt. (www.partstree.com) (model number is usually under the seat of the mower.)
    Apr 26, 2017 | Troy Garden
    How to adjust drive belt on troy-bilt pony tractor
    pony lawn mower? replace the drive belts.
    Mar 04, 2017 | Troy-Bilt Garden
    Mower belt diagram
    Try Goggle it. belt diagram troy -----
    Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
    Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
    hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
    May 15, 2010 | Troy-Bilt Pony Garden Tiller
    Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
  • Nov 30, 2009 | Mtd Garden
    Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
    Aug 17, 2009 | Garden
    I need to replace the transmission drive belt and need instructions
    There's actually a Troy-Bilt Pony riding lawn mower as well.  If yours is like ours, a model 13AN77TG766 [URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf], it doesn't actually have gears but rather a variable-speed pulley.  The lever on the dashboard actually controls how high the brake pedal will go, while the brake pedal controls the position of the variable-speed pulley, which controls the effective gearing ratio.  That's how it can go at any speed with the engine still going at the same rate and without having to disengage a clutch.
    So perhaps your mower is engaging the parking brake too early (page 17 of our manual).  The other thing I can think of is grass in the variable-speed pulley.  To check that, remove the spark plug and the battery (7/16-inch socket).  Then move the shift lever through its full range and check the shaft of the variable-speed pulley (part 63 on page 34) for debris, both above and below the loose plate thingy.  (You should be able to turn it quite easily if you put the forward/reverse lever in neutral.)
    Hope that helps!
    Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
    Changing the drive belt
    pull the bracket
    Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
    Garden Logo
    Top Troy-Bilt Garden Experts
    Jay Finke
    Jay Finke
    Roland W VanLue
    Roland W VanLue
    Tim Whalen
    Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
