Question about E-Machines eMachines Desktop PC
POWER SURGE ZAPPED COMPUTER.WILL NOT POWER UP..WHER IS THE FUSE
  • 30 Answers
The only fuse is in the power supply, if its totaly dead i would replace the power supply module. if that doesn't fix it the main board would also be bad
Posted on Jul 21, 2009
    President:
  • 1,564 Answers
There should be 2 glass fuses located near the top left corner of the mom board as you face it. They can easily be removed with a single tonged fork. bend three tongs out of the way and put a small curl in the last straight one with needle nose pliers. This will prevent the inevitable breakage of the fuse using pliers and the such. Check them well against bright sun or light. Good luck, Hope I helped in some fashion.
Posted on Jul 25, 2009
The CPU e-machine sparked when plugged in and now is dead.
No light when I try to turn it on. What should I do?
Posted on Jul 23, 2009
  • E-Machines Master
  • 3,051 Answers
Hello there
If you unplug the power supply and remove the power supply from the case. Now remove the screws that hold the cover on and remove the cover look on the inside and you will see a very small fuse if it is soldered in place this is hard if you dont know how to solder. If it is a fuse that can be removed good just remove it and get a new one radio shack has these or autozone ok than just replace the fuse and reinstall the cover and all screws and than reinistall the power supply back in the case and secure it. and power up the computer and see what happnes
I hope this helps
best regards mike
Posted on Jul 22, 2009
  • 144 Answers
Try a diferent cable the fuse might of blown uk only
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Sharp tv has no power
Sounds like your set has been zapped by a spike on the line. Now you know why UPS units and surge diverters were invented.
A new TV sounds probable as many components could be damaged. If you are lucky it could be just a fuse but I have my doubts.
Moral, invest in a surge diverter, it would have saved you a new TV
Apr 01, 2015 | Sharp LC 42LE540U - 42" Aquos LED...
No power after a power surge
Here's a link that will take you to the page for a few 5.23 models. You'll want to narrow the search on the left column by serial number to get to the correct information on your exact model.
Repair Parts for Precor 5 23 Ellipticals Consumer SPORTSMITH net
Here's a link to a few fuses that are listed for the 5.23's: To determine which one is correct, you'll need have your serial number off the machine:
Mar 17, 2014 | Precor Efx-5.23 Elliptical Machine...
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
Printer will not power up. May have been zapped by power surge in storm other night. Is there a internal fuse or reset button to try?
Same thing happened to me on same date 08-09-10.... on this site someone said to unplug it for at least 1 minute than plug it back in. It WORKED for me. Good Luck.
Aug 09, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
We had a power surge the other night. My computer
If it has fan power than all is well. The newer models can handle a zip verywell. What cannot handle it is RAM.
Most new power supplies have their own switch and it often times has a power off..
May 12, 2010 | Gateway Bestec ATX-300-12EB3 305w Power...
Have magic chef mcd990arb. it was zapped by power surge. what could have been damaged and it is worth repair
Well if it has been Zapped then usually it is only? the Power supply side of things, the Bridge Rectifier, Controller etc, especially if it wasn't actually "heating" at the time. But also it may have fried the Computer Chip, in the "Brain" of the microwave. These days though, it often costs more to repair than replace, and anyway I always say, if you fix it you still have a fixed thing that may have further problems, as things go. If it's new at least you can take it back.
Feb 06, 2010 | Microwave Ovens
No power to heater starter or radio
could have surge and blown smaller fuses
Apr 22, 2009 | 1994 Ford Explorer Limited
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
E-Machines eMachines Desktop PC Logo
259 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
