Question about GE Refrigerators
Where do you find the condenser on/ off switch for GE profile French door refrigerator?
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
SolutionGuy
  • 331 Answers
SOURCE: I have a ge french door refrigerator with two
Hi Laura,
The repair guy did what any repair guy would have done under a warranty situation such as yours... door gaskets. I presume he explained why he was doing what did ("why's" are important, ya know...). If he didn't, let me run through it real quick, OK?
Warm air holds moisture and cold air doesn't... that it in a nutshell. But what's important to note is that if there is an air leak inside your freezer you'll notice it just as you have, with condensation forming. This tells the repair guy that cold air is escaping and warm air is entering the freezer. The first place to look is the door gasket and that's why he replaced it. But now you know it wasn't the gasket, right?
So the repair guy didn't find the source of the air leak. It happens. The reason is that most "factory" tech's are trained on the fly and have the habit of not looking too deep into a problem 'cause they're warranty guys. They get paid whether or NOT a problem was fixed. See? Independent repair guys like me only get paid WHEN the job is fixed. So there's a GREAT incentive for me to get it right the first time, right? (I'm not "bashing" them. I'm just clarifying that warranty repairs are hit and miss at best.)
The thing you gotta think about is "How many places are there for cold air to escape and warm air to enter?" The answer to that question is "4". Yep. FOUR places that this can happen and each of them have to be inspected for evidence of moisture. They are;
1.) Behind the fridge where the ice maker water tube is inserted through the cabinet and into the freezer.
2.) Behind the fridge where the wire bundle enters the freezer compartment.
3.) Behind the fridge in the compresser compartment where the evaporator drain comes OUT of the freezer compartment.
4.) The door gasket.
Since your unit is still under warranty I certainly wouldn't expect you to chase these down for yourself. You should call GE again and have the repair guy come do this for you (print this out so you will have the above checklist). This is to protect your warranty, by the way. If you (or an appliance repair company NOT authorized to work on it) work on it, you run the risk of voiding the warranty altogether.
There's a product on the market called "PermaGum" (here's a link). It's used to seal air leaks such as this. When you talk to GE, try to insist that the tech have some on his truck when he arrives... I have the feeling that he'll need it because I suspect a leak is occurring in one of the top 3 areas I mentioned above (either that, or he didn't install the door gasket correctly in the first place).
As an aside? Just a tip/hint... I know that your fridge is new and all, but to KEEP the door gaskets like new for (almost) ever, use Vaseline on them. Yep, Vaseline. Open the fridge door, dab your finger into the Vaseline and smear a light (light) coat of it on the door gaskets all the way around. This will do 2 things;
1.) It'll keep the door gaskets from ever drying out.
2.) It'll provide a very good and air-tight seal when the door is closed. (air leak, Laura?)
There ya go! I hope this has helped you in your quest to rid you freezer of pesky condensation. If so, please remember to rate this as "It fixed my problem", OK? After that, you can mix up a Mojito and bask in the knowledge that you are a completely informed consumer when the GE guy gets there to finally fix your fridge.
Take care,
SG
Posted on May 07, 2009
projdoc
  • 2237 Answers
SOURCE: Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Posted on Aug 26, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
How to get the light to come on in the freezer side by side ge profile artica?
Open the door. The door switch should pop out, the light should come on. If the bulb is burnt out, that would hinder the process. If the bulb is good, I would start with checking voltage at the receptacle and work backwards thru the door switch until I found where the power was lost.
Sep 01, 2016 | GE Profile PFS22 33" Artica French Door...
Not cooling
Sounds like a defective start relay, run capacitor overload and possibly a defective condenser fan may have started the problem. What is the correct model number found around the fresh food section door?
Sea Breeze
Mar 06, 2013 | GE Profile PDCS1NB Bottom Freezer...
French door refrigerator with bottom freezer. I do not have the ice maker connected. Makes buzzing sound, likely the freezer part is making the sound. The buzzing sound comes and goes and is louder...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile PDS20SFSR Bottom Freezer...
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Ge profile french door bottom freezer the freezer temp has been fluctuating form 4 t0 14 degrees have been using turbo cool control to reset drops the temp but by the end of the day its back up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 28, 2009 | GE Profile PFS22MS Bottom Freezer French...
Door condesation
Hi, THere is either a door seal leaking or the moister switch located on the control panel is turned off. Check your door seals to make sure there are no rips.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 02, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
