Question about Dell 2135cn All-In-One Laser Printer
Can I print wirelessly from my Sony windows 10 laptop to my Dell 2135cn printer?
  • Dell Master
  • 787 Answers
Yes. Dell has made available both 32 bit and 64 bit Windows 10 drivers for this device so it should work on you Sony. This printer is network enable but it is wired, not wireless so you will have to connect it to your network with a ethernet cable.
Here are the drivers:
Support for Dell 2135cn Color Laser Printer Change product
Here is the manual:
http://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers/dell-2135cn_user%27s%20guide_en-us.pdf
Posted on Feb 08, 2017
My Dell 2135cn printer is printing Black when I'm calling for green. The color cartridges are full
If cartridge that has the blue & yellow (combinds for green), is low or out or clogged or defective, printer will automatically print black. Get some hot (almost boiling) water, then take color or all cartridges out of machine, put in container with about 1/4" of the hot water and let set for awhile. Do not put entire cartridge just the bottom where the print heas is located. The take paper towel and gently remove residual water from water. Replace, do print clean cartridge on your printer.
Edwin
Oct 11, 2014 | Dell 2135cn Color Laser Printer
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Dell 2135cn only uses about half the toner in the cartridge before it will quit working. How do I fix this?
cindy1929,
Remove the toner cartridge and look at both ends. There should be a clear window on each end for an infared beam to shine through. When full of toner the beam is blocked but apparently you have a sensitive sensor which can detect the beam before the toner is gone. Carefully place a small piece of opaque tape across the window to block the beam. Make sure that the tape is secure and will not fall off inside the printer. This should solve your problem and allow your printer to print until the toner is completely empty.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 07, 2011 | Dell 2135cn All-In-One Laser Printer
I am having print quality issues on a Dell 2135cn MFP - print on the left side of the page is light.
Try removing the toner cartridge and gently rotating it back and forth. Often the toner will bunch up like a snow drift and where there is little toner you'll have light or no print. If that doesn't do the trick try another toner cartridge.
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
What is the part number for the dell 2135cn phd (print head device) Thank you!
I believe the part number is 330-1435 or P266C or Y459D
(these all are for the same part on the website - Dell uses multiple numbers to refer to the same item)
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=330-1435
Feb 10, 2011 | Dell 2135cn All-In-One Laser Printer
Dell 2135cn black toner prints light grey
The way I resolved the issue is to go to the Printer... literally walk to it (not via Windows or a Driver), Select Menu button on printer->Setup->Admin->Maintenance->Clean Developer. This will clean each toner cartridge or PHD unit, or to stir the toner in a new toner cartridge. Then it started printing solid black again.
It took me hours to resolve this but I hope it helps someone else and spares them the pain.
Aug 13, 2010 | Dell 2135cn All-In-One Laser Printer
Dell 2135cn All-In-One Laser Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
