Question about Dryers
Broan ceiling fan making noise. How to replace fan
SOURCE: ceiling fan makes a clicking noise
just apply some lubrication and if necessary change the ball bearings. u r all set
Posted on Oct 07, 2008
  • 10865 Answers
SOURCE: new ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
Posted on May 16, 2009
rtpflh
  • 546 Answers
SOURCE: 52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Posted on Sep 21, 2009
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Posted on Apr 23, 2010
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Posted on Aug 01, 2010
Fan makes a odd noise when mounted in ceiling but not when removed and plugged in?
Try putting some insulation of some sort between the ceiling and the fan frame.
Jul 24, 2013 | Broan-NuTone QT110 Fan
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Replacement Motor for the NuTone LS80SE Ceiling Fan
https://www.centralvacuumstores.com/nutone/fan-motor-ls-series.php
Feb 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
QT 100L replacement
Don't worry, you can purchase just the fan from amazon (not entire motor). here: NuTone 0696B000 Motor Assembly for QT100 and QT110 Series Fans. I hope this was helpful. cheers
Oct 12, 2007 | Broan-NuTone QT100L Fan
Dryers Logo
23 people viewed this question
Top Dryers Experts
