Question about Kyocera Cell Phones
Kyocera limit use code lost. e4218 model. I own it and can prove it sprint won't reset it they want to wipe it. I need my data. Can I transfer it to my pc with usb cable. Win 7 32 bit op system
I though I would block callers not on my list of contacts Now I can't call others or sent texts. I paid $200.00 for this phone and I can't fully use it.
  • 12 Answers
SOURCE: Blocking Calls
No, actually, there is no way of blocking text messages, just incoming calls. Cheers
Posted on Sep 05, 2007
SOURCE: Need to transfer photos from Samsung Sync phone to PC with Windows Professional
check Bit Pim at www.bitpim.org, I have the same cell phone but I don't have the usb cable.
Good luck.
Posted on Jul 29, 2008
SOURCE: HAVE A CA 45 CABLE FOR NOKIA 16OO- NEEDS DRIVERS FOR IT
usb data cable dirver
Posted on Nov 26, 2008
mcsevishwa
SOURCE: cell phone (LG KP199) to PC (Win XP) USB data transfer problem
When you connect your phone to the PC, it shows two options for connecting: Mass Storage and Cell phone. Select mass storage.
For connecting in Cell phone mode you need to have the PC Suite for this model which as on date is not available.
You can use any third party softwares like mobimb, Mobtime Cellphone manager etc. for connecting to PC.
Posted on Jan 21, 2009
  • 18 Answers
SOURCE: phone can not be identified by the pc. it wants the usb charging
micro sd card has a built in driver on its own, all you have to do is to unlock your phone and connect the cable to your phone and your pc.. press "yes" on your phone questioning you "connect as a storage device" or something like that.. then you can start file transfer from pc to phone and vice versa..
Posted on Feb 11, 2009
Need to know how to hard reset Kyocera QCP 3035 cell phone.
hard reset
press and hold down the volume down button and power button when the screen comes on release your finger off the volume down button then press the volume down button again
will go to recovery mode
go to wipe data by using the volume down button highlight wipe data press power button to ok it
then go down to yes with the volume down button highlight yes then press power button to ok it will reset it
then it will go back to the writing go to reboot highlight reboot then press power to ok it
will restart the tablet
Mar 17, 2018 | Kyocera Cell Phones
Kyocera model number c6745 how to reset
Hold down the Power key in order to switch off the cell phone.
In this step press and hold the Volume Down
+ Power button for a few seconds.
You should release held keys when the
Recovery Mode starts.
Afterwards press Volume Down a few timies
to highlight "wipe data/factory reset ", and
then push the Power button to confirm this
option.
Next, select "Yes--delete all user data ". Use
Volume buttons to scroll and Power rocker to
select.
6. When the Recovery Menu appears
on the screen, choose "reboot system now ".
Oct 11, 2016 | Kyocera Cell Phones
How to unlock kyocera flip phone when I forgot code
Hi Tammy Townsend,
If you forget the screen lock password the hard/factory reset should help. But it will wipe down all data. How to hard reset KYOCERA phone HardReset info
If you need unlock code you can try https://www.mobileunlocked.com/kyocera
Mar 16, 2016 | Kyocera Cell Phones
Unable to get wi-fi to kick in and hold for a call. although it works just fine in store.
Troubleshoot issues related to data connectivity and your ...
support.sprint.com/...Kyocera.../WTroubleshootingGu...
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Troubleshoot issues related to your Kyocera Hydro Edge ...
support.sprint.com/...Kyocera.../WTrendTroubleshoot...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
Brigadier by Kyocera Support ' Verizon Wireless
www.verizonwireless.com/support/brigadier/
Verizon Wireless
Dec 13, 2015 | Kyocera Cell Phones
Can you walk through set up to reset my phone
Press and hold both Volume Up + Home+power on. In the recovery menu select wipe data factory reset with Volume button. Press power to confirm. After hard reset completed, select reeboot system now! All data will be lost!
Feb 08, 2015 | Samsung Galaxy Note 3 Android Smartphone...
How do you transfer data.to sd.card on sprint kyocera milano phone
In order to transfer data from an SD card on this device, press menu, tap import/export, then tap export to sd card, click okay, then confirm export or import
Jul 28, 2013 | Cell Phones
How do you transfer internal data to the sd card on sprint kyocera milano
there is usually a category in settings that will let you transfer the data back and forth
Jul 28, 2013 | Cameras
Unlock code sprint
To better assist you, I will need to know what you are wanting to do with the device; ie factory reset, overseas travel, subsidy unlock code(s)
Jul 11, 2013 | Sprint Sanyo Vero by Kyocera, Model SCP...
I forgot my unlock code....
i gorgot my code to my phone and i dont even remember my numbr
Aug 08, 2008 | Kyocera wild card Cellular Phone
Resetting
sounds like corrupt files on it. Need to Wipe the Device (aka hard reset). BUT DONT FORGET IT WILL LOSE ALL YOUR DATA
Feb 09, 2008 | Palm Treo 700p Smartphone
Cell Phones Logo
43 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
