My mp3 player has volume driver in it is there any other driver to install in it because my node is not charging....pls help me
  • 29 Answers
SOURCE: can't turn on my mp3 player
check to see if it shows up in your computer managment, go to your control panel, open up, administrative tools, open computer managment then go down to disk managment and see if you drive shows up there. if it does, right click, and choose format, and try formatting it again, something may have went wrong the first time, or maybe you formatted it in the wrong format.
Posted on Aug 12, 2006
SOURCE: SanDisk Sansa E280 MP3 Player
just go to piratebay.org and search for it and download it.
Posted on Dec 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: THE CLIP WON'T CHARGE
The hold switch might be engaged - unlock it.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
SOURCE: i have lost the cd for the driver installation for
i have one that i dont use
Posted on Apr 10, 2009
  • 3 Answers
SOURCE: How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Posted on Apr 23, 2010
How to charge a zebronics node mp3 player
Hi Sudarshan
It is charged through USB. Plug it in to a USB port of Laptop or Desktop or connect it to a USB Charger. Make sure that you do not drain the battery completely. When discharged do not keep it without recharge for a long duration . .
Hope this will help you
Sep 14, 2013 | iRiver B20 Auto Vent Holder with Car...
It won't connect to my PC, says driver not found
If the volume + method didn't work, then there is some feature about your PC config that is not going to work with this player. you can try the FAQ method on Philips website for when the PC is not recognizing the player, but I've never seen a case where it was successful.
Jul 28, 2008 | Philips SA5125/37 MP3 Player
Software for charging my creative zen v mp3 player
Go to Zen website and look under support for drivers etc
Jul 25, 2008 | Creative Labs Zen V MP3 Player
Screen keeps blinking and you cant turn off when charged. cant see anything on mp3 dont know if it has drivers
Look for drivers, install software first
if that fails:
Jun 25, 2008 | Audio Players & Recorders
My computer doesn't recognise my YP-K3J
May 29, 2008 | Samsung YP-K3 MP3 Player
Device driver problem
Hold in volume + and connect the goGear to computer - after continuing to hold the volume + for 10-30 seconds, Windows should reinstall the missing drivers
Apr 20, 2008 | Philips SA5125/37 MP3 Player
T20 makes me mad
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Apr 05, 2007 | iRiver T20 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
