Question about Geotrax Toys
Where can i find a Geotrax Christmas Train? - Geotrax Toys
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: One of my son`s train (Fischer-Price GeoTrax) not
Hi.
You need to contact Fisher Price customer service page:
##Customer Service - Fisher-Price
If they cannot fix the problem, contact Mattel customer service, that is on top of FP:
Mattel
Posted on Nov 09, 2010
  • 5 Answers
SOURCE: I have a geotrax train that is not responding to
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets **** and hitting it will get it going. All three engines are working now.
Posted on Dec 14, 2010
Train lights up but doesnt move
Tried smacking the train on the concrete, didn't work. Then I smacked one side, then the other, the wheels started turning like a charm. Getting the train set up for my 3 year old grandsons visit. One happy grandma right now.
Nov 25, 2013 | Fisher Price Geotrax Remote Control Train ...
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
Geotrax remotes work..trains wont go. I have cleaned contacts..new batteries...and cleaned axles
Aha! I found this on another forum and it worked for me!
I had some luck using a trick I read on the yahoo geotrax group.
Make sure you have good batteries and hold the controller in the forward movement position. Then run the train forward repeatedly on a surface with friction (I used my pant leg). I got two old trains to work again, and I'm hoping to fix one more.
The theory is that this works because it uses a magnetic coupling instead of a direct drive.
It only took me one super gentle swipe across my leg! Better than smacking/bashing them because that can knock wires loose and stuff. Hope this helps everyone! :D
Jan 26, 2011 | Fisher Price Geotrax Remote Control...
How do I fix a geotrax engine that came unsoldered?
Hello dot2607, if you took it apart and seen it disconnected at the soldered point on the little green circuit board then you can get a solder gun and solder it back. If you assume that this has happened then you can take it apart by unscrewing the bottom of the train and pull the body frame of the train off very gently. Make sure not to pull to hard because if its not broken the soldered wire can be pulled off of the circuit board when you open it. You can test it after to see if the little red light turns on located on top of the trains body frame. Wallah!!
Dec 23, 2010 | Toys
The controller for my geotrax train is not working...any tips?
Yes! Thank you! Holding the remote in forward and running the train over and over worked! It took me a few tries, and finally I did it for about 30-40 seconds continuously, and it worked!!!! Thank you!!!
Dec 18, 2010 | Fisher Price Geotrax Remote Control...
I have a geotrax train that is not responding to its remote. I put brand new batteries in it and it still does not work. The remote makes the noise and the red light lights up on top of the train. Is there...
Dec 01, 2010 | Fisher Price Geotrax Remote Control Train ...
One of my son`s train (Fischer-Price GeoTrax) not response to the RC, where can I send it to repair?
Hi.
Mattel
Nov 09, 2010 | Toys
GEOTRAX REMOTES ARE NOTE COMMUNICATING WITH TRAIN ENGINES. SET HAS BEEN IN STORAGE FOR A YEAR. WE SET UP AND CHANGED ALL BATTERIES, HOWEVER, REMOTE DOES NOT MAKE THE ENGINES MOVE. REMOTE DOCKING STATION...
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
Oct 17, 2010 | Fisher Price Geotrax Remote Control...
Toys Logo
35 people viewed this question
Top Geotrax Toys Experts
Tom Chichester
Are you a Geotrax Toy Expert? Answer questions, earn points and help others
