Question about Hoover Refrigerators
My Hoover 600a fridge freezer not working.I have changed thermostat but although fridge freezer appears to start it does'nt cool.
  • Hoover Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
1-3 TEMPERATURE CONTROL
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
http://www.appliancerepair.net/refrigerator-repair-1.html
https://www.youtube.com/watch?v=KqXN-ZCuptk THIRMISTOR CHECK
https://www.youtube.com/watch?v=53ZFeiWgtuk
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Top Freezer Thermistor Testing Replacement Troubleshooting Thermistor Problems in Refrigerators http://www.appliancerepair.net/refrigerator-repair-1.htm Refrigerator Is Not Cooling What To Check And How To Fix
Posted on Jan 07, 2017
My refrigerator does'nt defrost
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 30, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Hoover fridge freezer hnmf2605a/80 fridge freezeing up all the time
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Hoover Refrigerators
The fridge section does not appear to be keeping goods cool although temperature on front of fridge says 1 degree
Freezer fan not working or blocked by over ice formation behind the freezer. Switch of a/c for defrost. After some times, plug on . It's due to malfunction of defrost cycling. Keep thermostat at 5 degree and check thermostat, timer and defrost heater are working properly. thanks.
Jan 31, 2011 | Samsung RS2534 Side by Side Refrigerator
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
I have a Hoover upright fridge freezer which is not cooling in either fridge or freezer unit, the thermostat control does not click when turned up or down. the appliance is 4.5 years old. model no....
IF THIS IS FROST FREE IT DOES NOT USE THERMOSTAT BUT A CONTROL BOARD. LISTEN TO COMPRESSOR ,IF RUNNING THEN GAS IS LOW(R600a) LOOK FOR YELLOW TRIANGLE ON COMPRESSOR. IF IT RUNS TOO LONG LIKE THIS COMPRESSOR WILL RUN BUT NOT PUSH. ONLY WAY TO TELL IS TO PAY FOR AN ENGINEER TO COME,FIT A VALVE AND CHECK IT. JON THE FRIDGE DOC.
Mar 07, 2010 | Hoover HMA280K Bottom Freezer Refrigerator
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
