The switch started giving out. At first it would work intermittently and as long as I kept the machine on it
Fisher and Paykel ED56 start/pause button keeps blinking.. wonts start
Possibly the door switch is playing up, this model can be susceptible to the door slightly bending and not contacting the switch every time. give a gentle press at the top of the door to see if you can hear the door switch mechanism working.
Sep 04, 2017 | Fisher and Paykel Washing Machines
I have a Sears Kenmore elite model #10045081400, I have an intermittent problem. Sometimes it works fine and other times after I load the washer set the cycle and press the start button, it just clicks...
suggest you call a repair service tho intermittent problems are really hard to pin down.might just be the door switch needs some adjustment and or a screw tightened
Sep 18, 2017 | Washing Machines
Airco seems to blow hot air most of the times, but cold occasionally
Seems like the blend door is intermittent,Like you said in some cases it works fine,Either the blend door is intermitent or the cycling switch is intermittent this is located on the filter drier when this pressure switch fails the A/C goes intermittent
Nov 23, 2012 | Cars & Trucks
Intermittent heating
From the description you have a bad latch switch on the door caused by build up of food particles or ware.
Mar 05, 2012 | Bosch HMV9305 Microwave Oven
Washer worked fine early Sunday, then Sunday evening I was washing and kept getting this F11 error. It now has standing water inside of the washer and when I press the button to start the cycle the motor...
F11: Pump related. Pump not able to empty water correctly. More blockages to check for: something inside the pump stopping it or reducing it speed. Sump hose blocked between the outer drum and the pump. Outlet hose blocked between the machine and the U-BEND. The pump could also be weak, pumping too slowly, or intermittent.
Feb 24, 2010 | Washing Machines
02 Intrepid interior lights intermittent
the dimmer switch may be going bad--at night do you may see a change in the dash lighting as well --maybe even going off all together---sometimes adjusting the dimmer switch may give a temporary fix -the switch controls dash and dome lights and is a part that does wear with use
Aug 21, 2009 | 2000 Dodge Intrepid
My 2001 Denali cruise control does not work. It will not power up and all fuses are good.
I have a 2001 Chev pickup with the same problem and I've found that the switch on the stalk on the column is intermittent. If I flick it a couple of times, and turn it on and off it usually starts. It has done that for a couple of years and kept me lazy enough not to replace the switch.
Jun 15, 2009 | 2002 GMC Yukon XL
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Intermittent - might it be shared outlet pipe?
i doubt it it ,when you click it on manually does it carry on if so it sounds like it will be the carbon brushes goodluck dont forget to unplug
May 25, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
