Question about Keurig Coffee Makers & Espresso Machines
How do you clean a keurig coffee maker with white vinegar?
ThaMp3Doctor
  • 8596 Answers
SOURCE: funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Posted on Apr 04, 2009
  • 18 Answers
SOURCE: Keurig B50
I have the same problem, but overcame it with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a not as convenient as K-cups, but better than throwing out a $150 coffee maker.
Posted on May 21, 2009
SOURCE: Descaled the Keurig - light still on.
Try running water through without the K Cup inside. My machine has the same problem and the "descale" message goes away after using this procedure. I am beginning to think that the bottom line on all of this is a pump that is steadily weakening.
Posted on Jul 26, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Clean light continues to flash even after several
Unplug the coffeemaker for one hour or longer and it should reset itself.
Posted on Sep 29, 2009
heatman101
  • 43501 Answers
SOURCE: I cleaned my Keurig with vinegar. Ever since the
Check out this tip about how to descale your Keurig coffee brewer
How toDescale your Keurig Coffee Brewer
heatman101
Posted on Apr 02, 2011
How do i clean a keurig coffee maker?
Use white vinegar only. Do NOT use wine vinegar, flavored vinegar, balsamic vinegar, etc. Buy the cheapest one that you find in a supermarket. Fill the reservoir up halfway and run it through until empty. Then flush with plain water with TWO (2) full reservoirs of plain tap water.
Sep 18, 2014 | Keurig Coffee Makers & Espresso Machines
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Aug 17, 2014 | Keurig Elite B40 Coffee Maker
How to clean keurig coffee maker
It might be time to clean your keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
Apr 28, 2014 | Keurig B60 Coffee Maker
Keurig coffee maker does not brew
Re prime and reset feature options.
Jul 28, 2012 | Keurig B60 Coffee Maker
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Apr 25, 2010 | Keurig B60 Coffee Maker
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
Apr 05, 2010 | Keurig Elite B40 Coffee Maker
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 09, 2009 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
