Question about Dryers
I cannot keep the bonnet in the up right position to use it....did a clip or clamp or attachment pop off or got lost...it did work correctly the 1st time i used the dryer
  • 548 Answers
SOURCE: 1994 lincoln clip that attaches mortor to wiper arm keeps popping
Make sure the wipers are in the parked position - fully at the bottom of their travel. Haynes guide says to then put a wrench on the motor drive crank and a wrench on the bolt to get the bolt off
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: 30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
Posted on Jan 12, 2009
yooperbud
  • 8637 Answers
SOURCE: installation
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 23, 2009
  • 181 Answers
SOURCE: bonnet will not open as clip on bonnet is gone.
Depending upon how familiar you might be with the location of the under-hood release, you may be able to access it through the small opening between the hood and grill that follows opening the bonnet by pulling the lever under the steering wheel. A long narrow standard head screwdriver and a good light may be all that is required. That is exactly how the mechanic at the VW garage will release the hood latch.
If your not at all familiar with the hood latch, it might be useful to view the mechanism in another Passat so that you know how it functions. Less than a 5 minute job, but the dealer will likely charge about $65 to perform the task, substantially more to replace the broken mechanism.
Posted on Jul 14, 2009
maadgar
  • 44 Answers
SOURCE: I have attached to a plastic garbage can, the hose
dryer vent clamp should work o.k.. make sure the garbage can is vented so air can escape. cut a @ 4" hole in the can near the top (or in the lid) and use silicone to cover the hole from the inside with household window type screen
Posted on Nov 14, 2009
Found a cracked coolant hose connecting metal tee with two ******* for hose attachment.
Buy the replacement part.
Loosen-off the securing clamps or clips which hold all the hoses onto the junction pipe.
Remove the damaged part & put the new one in position.
Re-tighten or secure all the clips or clamps holding the hoses in position.
Top up the water in your header tank.
Best of luck
Mar 15, 2018 | Cars & Trucks
Why will the walking foot number 1/p60443 not work on my berina virtuosa160
Are you not able to attach it to your machine or does the walking foot not work properly once it is attached?
The number should fit your machine unless someone inadvertently sent you the wrong foot.
If it attaches but doesn't "walk" when you sew, then it is not installed correctly. Be sure the needle clamp screw is "inside" the C-shaped lever of the walking foot. Hint: it helps to tilt the walking foot when installing in order to get it in the correct position for attachment as well as getting the C-clamp around the needle clamp screw.
installing Bernina walking foot Google Search
Aug 07, 2017 | Sewing Machines
How to replace bonnet struts WK holden statesman
To Replace bonnet struts on a wk statesman you will need to flow the procedure below.
1.Open the bonnet fully
2.Replace one at a time .
3.Now bonnet is open grab pole and place under bonnet for extra support.
4.The strut will be mount to a ball and on the side you will also see a little rectangular clip .
5.Use a small flat blade screw drive to pop clip out once the clips out you will be able to gently work the strut off the ball on top and bottom.
6.same procedure to fit new strut
hope this helps
Jul 07, 2014 | 2006 Holden Commodore SS
Where is the bonnet release catch on a ford focus
Go to the ford badge at the front of the car
Swivel the badge (its spring loaded)
Insert your ignition key and turn to the left (position 1)
The bonnet should pop up
Turn the key to the right (position 2)
You can now lift the bonnet.
Sep 20, 2010 | 2002 Ford SVT Focus
I lost the keys to my suzuki grand vitara 2006 so until i can afford new ones I was planning on using my remote. my remote still starts the car but it will not lock or unlock the doors anymore so i'm...
Assuming you are referring to the battery in the key fob try the link below.
If it is the car battery open the bonnet and remove the cover. Using a spanner or a socket, usually a 10mm, remove the negative terminal, (-/black). Then remove the positive terminal, (+/red). There might be a mounting clamp you need to remove to lift the battery out. It is usually across the body of the battery or around it's base.
**Note which way round the battery sits as connecting it up wrong WILL cause serious problems.**
Re-sit the battery into position.
**Keeping it the correct way round!**
Refit the mounting clamp.
Refit the Positive terminal first.
Refit the Negative terminal second.
DO NOT OVER TIGHTEN THE NUTS. How To Replace Suzuki Grand Vitara Key Fob Battery 2004 2005 2006 2007 2008
Jan 18, 2018 | Suzuki Grand Vitara Cars & Trucks
Can't get needle stay in the clamp ?
On the 237 there should be a very small piece of round metal that fits into the needle clamp so when it tightens it keeps the needle in the correct position, you may have lost that small piece of metal.
May 21, 2010 | Sewing Machines
Where is the fuel filter on a x5 diesel
Its under the bonnet, Pop the bonnet, as you stand facing the engine its up high on your right, the cars left side. its found by following the black plastic air intake to a mini radiator sort of thing which is the fuel cooler. the Fuel filter is the silver, soft drink can sized thing just behind that mini radiator thing. Its clamped around by a clamp which is tightened by an Allen key/Hex head thing, which is a common size in any set you would buy from any auto store. use a Phillips head screw driver to loosen the two flexible fuel lines and disconnect them. Unclip the plastic sensor from the top of the filter with thumb and fore finger and slide the old filter up and out. Reverse to replace. When everything is redone turn the key to the on position while the pump primes the filter and check for leaks. These should be done every 3-4 oil changes. Happy motoring!
May 05, 2010 | 2005 BMW X5
Hi! I am planing to buy BMW X5 3.0 diesel 1999-2002, is it equipped with fuel filter and how sensitive is the engine to poor quality fuel? Thanks.
yes fuel filter is installed and must be changed every 10 000 km like clock work but it is a lovely car and you will have lots of fun
Jun 08, 2009 | 2005 BMW X5
Jan 04, 2009 | 1984 Volvo GL
Dryers Logo
26 people viewed this question
Top Dryers Experts
