Question about Sanyo Microwave Ovens
I have bpl sanyo microwave oven...i dont know its functions which r given on that.who will help me for that..
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven, sanyo,not heating
With no heat and louder noise, chances are you have a shorted high voltage rectifier diode or bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Posted on Aug 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
SOURCE: smeg fmc24x oven and grill work turntable and microwave dont
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
Posted on May 05, 2009
SOURCE: Hi, I have a BPL
where do i get manual of BPL Sanyo BMO 700 T
Posted on Sep 21, 2010
  • 8909 Answers
SOURCE: I have BPL Sanyo Microwave
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
The cooling fan and turntable motor get their supply from the same point as the main transformer. If the magnetron or diode has failed that will cause excess current to be drawn and take out the supply fuse.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Nov 23, 2010
I have a Sanyo Microwave EM-2500T, serial number 508650448 and I need to know the maximum wattage of it please. It was given to us second hand 23 years ago and is still going strong!
Hi Alison!
Wow. That microwave certainly doesn't owe you anything. Nice work on 23 years.
While not able to come up with the exact specifications or owner's manual, I would guess that 850 to 1000 watts would be pretty close to the number for your unit, especially if it's running on a 15A breaker.
Sorry I couldn't have been of more help.
-Steve
Mar 31, 2015 | Sanyo Microwave Ovens
How do i fix a sanyo microwave
call ser. tch. ur motor might be spoiled already . its a added function mabe of the unit if ur turntable motor not wroking so does ur microwave
Feb 21, 2015 | Sanyo Microwave Ovens
How do i unlock the control key pad on a sanyo super showerwave
Try holding down the Stop button for approximately 5-10 seconds. This is the industry standard for locking and unlocking microwaves, although your Sanyo may vary. Please let me know if this helps!
Mar 01, 2011 | Sanyo EM-A5200SW Microwave Oven
Why i should pay for on line guidance of your product
well i dont know what your problem is but i will be happy to help
Feb 27, 2011 | Sanyo Microwave Microwave Oven
My GE overrange microwave stopped working.
pls help me now my sanyo machine have problem
Jul 25, 2009 | GE JVM2050 Microwave Oven
Sanyo microwave fuse blowing -drawing too much current
Wow, I've never heard of a microwave having a circuit breaker on the main board.
I would suggest that you test the capacitor and the high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
Nov 09, 2008 | Microwave Ovens
Microwave oven, sanyo,not heating
Aug 18, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
