Question about Dremel Tools & Hardware - Others
Carving stone with a rotary tool
I want to carve the house and street names into a hard rock using my dremel multipro 395
    Sergeant:
  • 384 Answers
Are you asking for permission? If so, it OK with us, better check with your wife and her mother.
Posted on Jul 21, 2009
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
The tool will not turn on, it stopped in the middle of a project
One of my dremels shorted out because some grinding got into the housing. You may also want to check the brushes if you have used it a lot.
Sep 03, 2010 | Dremel Variable - Speed Multipro Rotary...
How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Damaged amature causing lack of speed variablity?
That could cause a problem not allowing the brushes to seat properly. Does it arc excessively? If so you might need a new armature. Also while you had it apart did you check the bearings for being rough or tight?
Nov 23, 2008 | Dremel Variable - Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
138 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
