Question about Keurig Coffee Makers & Espresso Machines
Change filter on Keurig 2.0 400 - Keurig Coffee Makers & Espresso Machines
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
How do I order a filter for my Keurig?
You must be more specific about "filter".
Are you inquiring about the "My K Cup" reusable wire mesh filter to use your own ground coffee? You can order them online through Amazon. Here's a link:
http://www.amazon.com/Keurig-K-Cup-Replacement-Coffee-Filter/dp/B009VIUI04/ref=sr_1_6?s=home-garden&ie=UTF8&qid=1442776181&sr=1-6&keywords=Keurig+filter
If you're asking about Keurig charcoal water filters, here's a link for that on Amazon:
http://www.amazon.com/Charcoal-Water-Filters-Replaces-Keurig/dp/B00HL2ZR2Q/ref=sr_1_6?ie=UTF8&qid=1417372516&sr=8-6&keywords=keurig+filter
Hope this helps. Thank you for using Fixya!
Sep 20, 2015 | Coffee Makers & Espresso Machines
Where do i change the filter?
The filter goes in the water tank on the 2.0 if you cant see it in there then you dont have one.
Jun 02, 2015 | Keurig Coffee Makers & Espresso Machines
Need source for replacement water filters
Nov 30, 2014 | Keurig Coffee Makers & Espresso Machines
How do you change the filter in a b60 kuerg
Take the reservoir cover off. Pull the plastic ring looking thing straight up and out. This holds the filter. Change the filter and plug the filter holder back in.
Jun 19, 2014 | Keurig B60 Coffee Maker
My Keurig says to prime
This video link below, from keurig, should get you back running.
remove reservoir, if you have a water filter, remove it and set aside. Use a damp non abrasive cloth and clean tank including filter screen. DO NOT DRY the inside with a cloth as lint may remain. DO NOT PUT in a dishwasher. Let it air dry. Reinsert the water filter. Put tank back into unit making sure it is aligned properly. Fill tank all the way up with clean water. Turn power on and attempt 3 WATER only brew cycles at the 6 or 8 ounce size. DO NOT USE A PORTION PACK.
If this doesn't work, you may have to clean the needles of the K-cup holder and / or the filter screen and water reservoir port.
If the problem persists you can contact you can contact Keurig at 1-866-901-BREW (2739) or Keurig.com
http://www.keurig.com/what-if-brewer-indicates-prime?cm_mmc=Google-_-Dynamic%20Search-_-Keurig-_-Keurig%20Homepage
Mar 09, 2014 | Coffee Makers & Espresso Machines
KEURIG B31
The exit tube at the top that penetrates the Kcup has debris from the minerals in the water you are using. Clean as per Pg 18 and use Distilled Water to avoid the problem. Change Filters 6-8 weeks periods, also.
Feb 10, 2013 | Keurig B31
How do i change the filter on Keurig model B77 ?
Pull Filter from wand and dislodge, replace with new filter.
Oct 27, 2012 | Keurig B70, B77, Platinum, Ultra Coffee...
How do you change the water filter on the Keurig B70?
Sorry to read about your problem, I hope this helps you out.
Their is no filter to change
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Keurig B70 Coffee Maker
How do I change the water filter ?
how do you change the keurig water filter?
May 19, 2010 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
