Question about Cross Office Equipment & Supplies
I have a Michael Graves cross cut shredder model MMG-PS2810. I moved and the waste basket wound up getting lost. Anyone know how I can get a replacement waste basket for it? Thank you.
SOURCE: Achiever CCS 5000 Basket
Manufacturer of Achiever CCS-500 new name Homeland Security Cameras (p)800-678-5891 Basket = 15.00 + shipping 7.00
Posted on Aug 22, 2007
t_vinson57
  • 58 Answers
SOURCE: This cross cut shredder stopped cross cutting.
Broken gear, or C-clip came out & gear slip off shaft, you won't know in teal you take out cover and look.
good luck and plug before working on!
Posted on Mar 26, 2009
goalie39
  • 469 Answers
SOURCE: what is the interlock for a staples shredder
if you look at the underside of the shredder, you will likely find a pressure switch that is actuated when it sits on the stock bin, either modify it to touch when on the new bin or secure it so it is depressed all the time. This should allow it to operate on the replacement bin.
Hope this is of some help.
Ed
Posted on Apr 20, 2009
  • 8404 Answers
SOURCE: Model 21306908, OM99912 No power to shredder. The
Look for a small fuse inside if you can open the power head.
Posted on Sep 07, 2009
  • 9 Answers
SOURCE: C-320C Cross-Cut Shredder need a parts list
get ahold of thetapped@yahoo.com he has parts
Posted on Mar 18, 2010
Where can i buy a replacement basket for my Royal SC120 12 sheet crosscut shredder
you may get one from the manufacturer spares on line
other wise take the top opening measurements of the container and you may get one from you local hardware shop in the plastic container section that will do as a replacement
Sep 01, 2015 | Royal 12 Sheet Cross Cut Shredder SC120
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Our P58Cs is no longer turning on - no lights come up. We swapped the fuse in the plug with a plug that is working but this didn't help. Does anyone have any idea why
"" Unplug the unit first! "" The shredder head "top" has a small silver safety switch on the underside, this has to engage with a TAB on the side of the basket for the unit to power up, carefully look on the underside for it. put it back on the basket, once engaged it should work.
BE CAREFUL.
Jan 19, 2011 | Fellowes P58CS Cross Cut Shredder
Need basket 4 rl170mx shredder
Give Royal a call at 1-800-524-0799 for parts.
Jul 31, 2010 | Royal 150MX Cross-Cut Shredder
GREEN POWER LIGHT ON RED LIGHT BLINKING MACHINE WILL NOT GO IN FORWARD OR BACKWARD
Common reasons for this is dirty or blocked sensors on top and under the cutter asm.Also, the waste basket door sensor or switch is activated.
Jun 03, 2009 | Achiever CCS-1500 Cross-Cut Shredder
Tripper combs broken on model DM8C Fellowes
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Mar 21, 2009 | Fellowes DM8C Cross-Cut Shredder
This cross cut shredder stopped cross cutting. Does anyone know how to fix it.
Mar 14, 2009 | Royal 85MX Shredder
Power transformer broke
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
Replacement part for model 9210PL
Good luck, Tom
Nov 13, 2008 | IdentityGuard Cross-Cut Shredder
69 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
gbob59
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
