Question about Breville Coffee Makers & Espresso Machines
I have a breville coffee maker grind and brew it grinds but will not briew
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Posted on Dec 16, 2009
  • 81 Answers
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Posted on Apr 15, 2010
vetteman3002
  • 2299 Answers
SOURCE: Grind and Brew Coffee Maker. Aborted
You should be able to unplug the machine and let it sit for about an hour to return to default settings.
Posted on Dec 15, 2010
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Where is the grind switch on the cuisiart grin & brew
Once you turn the machine on, it should automatically start to grind, unless you press the Grind Off button to make it stop.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Breville 800esxl
A card included in the operating manual indicates that this is normal. The Breville "Dual Wall Crema System" will do this. Visit www.breville.com for more information.
Nov 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
