Computer says the door open
Where the door of this printer?
  • kakima Jan 04, 2017
    Hi Pesta Siahaan, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "this printer"?
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
"Printer Door Open"
Uninstall then re-install the printer?
Apr 23, 2012 | HP Deskjet D2545 InkJet Printer
Service 5100
this problem caused by your cartridge cariage has problem to move
follow this step to fix
open printer door, the cartridge will move to the left
then close again
look at computer is the error still displayed
if yes
open printer door again, and gently move the cartridge cariage to the right, then move to the left again
and close the door
Mar 15, 2011 | Canon PIXMA iP1800 Printer
It keeps on sayin my access door is open but my printer doesnt have a rear door
Access door is usually the one that opens to allow the insertion of new cartridges. Try opening and closing that one and restarting the device after completely unplugging from the mains and waiting 30 secs.
Please rate this answer!!
Cheers
Bob
Jan 09, 2011 | Office Equipment & Supplies
Reads printer door is open when it is not open
Try restarting computer, I helped a friend with this issue and she is printing now.
May 14, 2010 | HP Deskjet D2345 InkJet Photo Printer
I helped a friend with this, I just had her to restart her computer and she is now printing.
Mar 23, 2010 | HP Deskjet D2345 InkJet Photo Printer
Printer light blinking. error message when I click on hp 3650 icon. ''printer door open'' can you advise? I rebooted computer.
when printer door open then printer carrage is unlock position? if you are right so your cartridge is ok other wise you change cartridge
or properly lock
Jul 07, 2009 | HP DeskJet 3650 InkJet Printer
Printer says door open
aah simple solution to that modiboni. you need to check if the printer door is still open but youv already tried that im sureoption 2 im not to sure on your printer but when you open the door chek to see o protruding plastic that will activate a switch to say the door is closed if you see that the plastic is broken use a small item to push down the sensor and it hopefully should read that the printer door is closed.
May 13, 2008 | HP Deskjet F340 All-In-One Printer
Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
Feb 03, 2008 | HP DeskJet 3650 InkJet Printer
24 people viewed this question
k24674
jasbo
jasbo
